sw5163
Post by sw5163 »
RESET_9999 wrote:
Fri Jul 15, 2022 12:22 am
@sw5163
do you have an mp4 version of quietvoid's L2 trim test file that works on the appleTV?
I don't have apple tv but I have rechecked these files, I think they can still be downloaded.
sw5163 wrote:
Mon Jun 27, 2022 1:50 am
Converted p8.1 sample:
Anyone can make this with the following command:
ffmpeg -i p81_cmv29_tests.mkv -c copy cmv29.hevc
mp4muxer -i cmv29.hevc --dv-profile 5 --dvh1flag 0 -o cmv29.mp4
They can directly play by iPhone in safari and have dolby vision.
Im not sure about ATV, but l2 trim works in cmv29 on iOS devices.
Only saturation in l2 works in cmv40 since cmv40 has l8 for replacement, according to quietvoid.
屏幕截图 2022-07-14 203631.png (55.34 KiB) Viewed 8021 times
sw5163 wrote:
Fri Jul 15, 2022 12:26 am
If it is not too much trouble, could you please show me what command you are using to generate DV mp4 with ffmpeg?
I would very much like to give it a try.
Im currently using ffmpeg dovi_tool mp4muxer and mp4box to generate DV mp4. The process is troublesome.
It will save a lot of effort, If ffmpeg alone can do it.
Many thanks.
did you try the old tsmuxer version that made fake p5 files?
https://drive.google.com/file/d/1ze3VfN ... sp=sharing
if it works then you have your solution and it's much faster than the mp4muxer.
sw5163
Post by sw5163 »
RESET_9999 wrote:
Fri Jul 15, 2022 12:47 am
I have just tried it, unfortunately Apple's internal player has very poor compatibility. As far as I know, it only supports mp4 in hvc1 or dvh1 codec. And I don't have other player to test them, sorry.
Oh I don't nesscessarily use mp4muxer. I mentioned it because it's official tool.
I personally use ffmpeg to extract, dovi_tool to mux, and throw them including subtitle to mp4box. mp4box automatically generate P5 dvh1 by default no matter what the real profile is. The speed seems fine, like 5 min for 70G file. So it's not exactly that bad.
Could anyone with an ATV confirm what @manix said please?
if @sw5163 method works, then I'll update the "playback devices sheet" and make a workflow for Apple users in my DoVi_scripts
because we have conflicting information...
viewtopic.php?p=123338#p123338
ragico
Post by ragico »
RESET_9999 wrote:
Fri Jul 15, 2022 2:35 pm
Tested the files cmv29.mp4 and cmv40.mp4 at my friend's who owns the ATV . The test was done using file explorer for mac (app) installed on the Atv and streaming directly from the Pc, so I think that apple internal player was used.
Both files played entirely in Dolby Vision without hassle.
Hope this can help RESET_9999
ragico wrote:
Fri Jul 15, 2022 10:44 pm
Thanks but did it have an RPU response?
ragico
Post by ragico »
RESET_9999 wrote:
Fri Jul 15, 2022 11:52 pm
I saw the light changing frequently from dark to bright on both files.
So I think yes.
ragico wrote:
Sat Jul 16, 2022 12:00 am
So I think yes.
yep, that confirms it , thank you.
Also, I just noticed that the mp4 created by the latest mp4muxer works on the C2 while it's HDR10 only on the C8(we have to use the old mp4muxer).
sw5163
Post by sw5163 »
Well, guess sometimes we need to break some rules.
Did you guys test infuse?
Theoretically, fake P5(HDR10 bl and RPU) in MKV should also play by infuse.
With mkv, it can have TrueHD, if ATV can properly handle it.
sw5163
Post by sw5163 »
RESET_9999 wrote:
Sat Jul 16, 2022 12:40 am
What do you mean? C2's internal player can also play FEL now? I thought only models before CX can do that.
sw5163 wrote:
Sat Jul 16, 2022 12:52 am
No, I'm talking about P8.
the C8 (probably the C7/C9 too) cannot play the DV MP4 created by the latest version of the mp4muxer. We had to use the older/first version of the tool.
sw5163 wrote:
Sat Jul 16, 2022 12:47 am
appleTV should be able to handle "fake p5" mp4 with LPCM.
staknhalo
Post by staknhalo »
RESET_9999 wrote:
Sat Jul 16, 2022 12:56 am
Wonder how/if the dvh1 flag has affected playback compatibility this entire time
sw5163
Post by sw5163 »
RESET_9999 wrote:
Sat Jul 16, 2022 12:59 am
True, so can all the iOS devices. lpcm(7.1), flac(7.1), alac(up to 5.1) works in mp4 container for apple native player.
7.1 loseless on iPhone built in speaker, lol.
