dwalme
#6826 Post by dwalme » Thu Jul 14, 2022 3:18 am
sw5163 wrote: Thu Jul 14, 2022 2:31 am
RESET_9999 wrote: Wed Jul 13, 2022 6:37 pm
Maybe update the Playback-Devices list?
It's been confirmed Apple TV and iOS devices can play BL+RPU with some conversion.
Or not, if that is considered conflicting to Dolby standards and rules
Apple TV can only play Dolby Vision P5 properly.
Infuse used to trigger Dolby Vision on TVs for some other profiles but it was only ever using the HDR10 base layer. They fixed it awhile back to stop triggering Dolby Vision on the display for those profiles.
If there is new information please link the source.
Jose1001
#6827 Post by Jose1001 » Thu Jul 14, 2022 11:39 am
One little question guys. I have a movie in FULLUHD with dolby vision that comes on 2 discs, and I want to create a single disc with a profile 8, how is this usually done, I create two profiles 8 with the Dovi_Scripts tool as if they were different movies and then join them, or one and then I create profile 8?
I have previously joined movies that came in 2 discs with HDR, and I also do my profiles 8 with the Dovi_Scripts tool, but until now I had not come across this case of joining a movie from 2 discs to 1 with dolby vision.
Thank you very much and greetings
#6828 Post by RESET_9999 » Thu Jul 14, 2022 2:38 pm
I've seen confirmation for the ipad but not for the appleTV yet.
Jose1001 wrote: Thu Jul 14, 2022 11:39 am I create two profiles 8 with the Dovi_Scripts tool as if they were different movies and then join them, or one and then I create profile 8?
yes, I think you can use tsmuxer or mkvtoolnix to join the two parts together
dvfan
#6829 Post by dvfan » Thu Jul 14, 2022 5:43 pm
sw5163 wrote: Tue Jul 12, 2022 5:38 pm
dvfan wrote: Tue Jul 12, 2022 12:41 am I'm wondering, using Sony A80J Internal Player ( via USB ) does not play mp4 profile 8 DV files converted by ffmpeg to mp4 ( it includes DV metadata ) though player says "File can't be opened"
Are you sure ffmpeg can configure the DV box correctly?
Im using ffmpeg 4.4, it seems it ignores DV when generating mp4.
Maybe try mp4muxer for proper DV mp4 generation?
Most TV internal player don't support DV in MKV.
Yes, upon checking mediainfo it shows Dolby Vision metadata but the file fails to play, same happened on a Hisense U7G so looks like ffmpeg breaks video with DV. TSMuxer with ts worked perfectly.
sw5163
#6830 Post by sw5163 » Thu Jul 14, 2022 11:48 pm
RESET_9999 wrote: Thu Jul 14, 2022 2:38 pm I've seen confirmation for the ipad but not for the appleTV yet.
Wait what, I thought Manixx2020beyound has tested it on ATV. Maybe I interpret it wrong?
But thanks any way.
Manixx2020beyound wrote: Mon Jun 27, 2022 8:39 pm Hum,
We’ll it plays doblyvision on my pc all trims as well & triggers pc dv.
Are the colors correct is a good question doe.
But I’ll test it on my appletv but I would say it should play on appletv.
Yes it plays on appletv & all the l/trims
And u can upload that to your apple tv library
Stream it from Mac m1 to Apple TV
Stream it form pc to Apple TV works
sw5163
#6831 Post by sw5163 » Fri Jul 15, 2022 12:08 am
dwalme wrote: Thu Jul 14, 2022 3:18 am
Sorry, I thought it's been confirmed last month. Maybe Im wrong.
Manixx2020beyound wrote: Mon Jun 27, 2022 8:39 pmHum,
I don't use infuse on my iOS device. The native player (quicktime?) through File APP works just fine for me.
Does ATV have some file sharing app that can play video using the internal player through SMB?
#6832 Post by RESET_9999 » Fri Jul 15, 2022 12:22 am
@sw5163
yeah, @manix can be hard to follow sometimes...
do you have an mp4 version of quietvoid's L2 trim test file that works on the appleTV?
sw5163
#6833 Post by sw5163 » Fri Jul 15, 2022 12:26 am
dvfan wrote: Thu Jul 14, 2022 5:43 pm Yes, upon checking mediainfo it shows Dolby Vision metadata but the file fails to play, same happened on a Hisense U7G so looks like ffmpeg breaks video with DV. TSMuxer with ts worked perfectly.
If it is not too much trouble, could you please show me what command you are using to generate DV mp4 with ffmpeg?
I would very much like to give it a try.
Im currently using ffmpeg dovi_tool mp4muxer and mp4box to generate DV mp4. The process is troublesome.
It will save a lot of effort, If ffmpeg alone can do it.
Many thanks.
sw5163
#6834 Post by sw5163 » Fri Jul 15, 2022 12:40 am
RESET_9999 wrote: Fri Jul 15, 2022 12:22 am @sw5163
I don't have apple tv but I have rechecked these files, I think they can still be downloaded.
sw5163 wrote: Mon Jun 27, 2022 1:50 am Converted p8.1 sample:
Anyone can make this with the following command:
ffmpeg -i p81_cmv29_tests.mkv -c copy cmv29.hevc
mp4muxer -i cmv29.hevc --dv-profile 5 --dvh1flag 0 -o cmv29.mp4
They can directly play by iPhone in safari and have dolby vision.
Im not sure about ATV, but l2 trim works in cmv29 on iOS devices.
Only saturation in l2 works in cmv40 since cmv40 has l8 for replacement, according to quietvoid.
屏幕截图 2022-07-14 203631.png (55.34 KiB) Viewed 21543 times
#6835 Post by RESET_9999 » Fri Jul 15, 2022 12:47 am
sw5163 wrote: Fri Jul 15, 2022 12:26 am If it is not too much trouble, could you please show me what command you are using to generate DV mp4 with ffmpeg?
Many thanks.
did you try the old tsmuxer version that made fake p5 files?
https://drive.google.com/file/d/1ze3VfN ... sp=sharing
if it works then you have your solution and it's much faster than the mp4muxer.
sw5163
#6836 Post by sw5163 » Fri Jul 15, 2022 1:01 am
RESET_9999 wrote: Fri Jul 15, 2022 12:47 am did you try the old tsmuxer version that made fake p5 files?
I have just tried it, unfortunately Apple's internal player has very poor compatibility. As far as I know, it only supports mp4 in hvc1 or dvh1 codec. And I don't have other player to test them, sorry.
Oh I don't nesscessarily use mp4muxer. I mentioned it because it's official tool.
I personally use ffmpeg to extract, dovi_tool to mux, and throw them including subtitle to mp4box. mp4box automatically generate P5 dvh1 by default no matter what the real profile is. The speed seems fine, like 5 min for 70G file. So it's not exactly that bad.
#6837 Post by RESET_9999 » Fri Jul 15, 2022 2:35 pm
Could anyone with an ATV confirm what @manix said please?
if @sw5163 method works, then I'll update the "playback devices sheet" and make a workflow for Apple users in my DoVi_scripts
because we have conflicting information...
viewtopic.php?p=123338#p123338
ragico
#6838 Post by ragico » Fri Jul 15, 2022 10:44 pm
RESET_9999 wrote: Fri Jul 15, 2022 2:35 pm Could anyone with an ATV confirm what @manix said please?
Tested the files cmv29.mp4 and cmv40.mp4 at my friend's who owns the ATV . The test was done using file explorer for mac (app) installed on the Atv and streaming directly from the Pc, so I think that apple internal player was used.
Both files played entirely in Dolby Vision without hassle.
Hope this can help RESET_9999
#6839 Post by RESET_9999 » Fri Jul 15, 2022 11:52 pm
ragico wrote: Fri Jul 15, 2022 10:44 pm
Thanks but did it have an RPU response?
ragico
#6840 Post by ragico » Sat Jul 16, 2022 12:00 am
RESET_9999 wrote: Fri Jul 15, 2022 11:52 pm
I saw the light changing frequently from dark to bright on both files.
So I think yes.
