John wick chapter 2 UHD
Mrxkenny
Post by Mrxkenny »
Just got makemkv and am trying to get John wick chapter 2 Uhd to work but unfortunately getting the volume key is unknown error. I’ve seen some others have seemed to get it successfully, could it possibly be my settings for my drive? I’m using a lg slim uhd drive, I’ll get the actual part number later today if that helps, I’ve already sent off my log file too
Re: John wick chapter 2 UHD
Post by d00zah »
The UHD FAQ is a great place to start... the Hashed Keys section.
Mrxkenny
Post by Mrxkenny »
Yes sir, looked at that before i proceeded with this. since the hashed keys are now downloaded on there own i dont see anything else i can do besides sending them the dump file which i have. i guess ill wait and see. i saw there is a new makemkv out today so maybe that somehow fixes my issues, idk just a thought
Post by d00zah »
It's likely just a new key. The time it takes to generate keys is variable, but if MakeMKV internet access is enabled, you'll get it. UHD ripping is often a waiting game.
Mrxkenny
Post by Mrxkenny »
yeah actually I was just able to rip it, so they worked their magic pretty fast, impressed for sure.
