dwalme
Post by dwalme » Tue Jul 12, 2022 11:27 pm
sofakng wrote:
Tue Jul 12, 2022 8:31 pm
Thanks... It seems like there isn't any perfect solution.
Is it safe to safe the Sony x800m2 is probably the 'best' choice?
I use three devices. X800M2 to play back all my Dolby Vision TS files using JRiver via dnla to control it.
I use a Zidoo Z9X for any Dolby Vision in MKV and the rest of my local media using HT 4.0 or now Jellyfin. I could easily use an Odroid N2 running Coreelec Kodi for anything not Dolby Vision.
Then I use other devices for direct streaming services (Apple TV 4K, TV Apps, Firestick, Roku, etc).
Everyone will have their preference.
sofakng
Post by sofakng » Wed Jul 13, 2022 12:34 am
Thanks for the advice.
If I don’t care about FEL, the would the Zidoo be a better choice than the x800m2? (you can convert FEL to MEL anyways, right?)
dwalme
Post by dwalme » Wed Jul 13, 2022 1:21 am
If I did not care about FEL I would not own the X800M2. I would only use the Z9X.
Yes the Z9X ignores the EL and plays back with just the RPU data.
sofakng
Post by sofakng » Wed Jul 13, 2022 2:35 am
I'm still learning, but I thought I read you can convert FEL to MEL without any visual loss of quality? (ie. no TV panels can display 12-bit FEL anyways?)
goomba22
Post by goomba22 » Wed Jul 13, 2022 4:28 am
Hi, I am wondering if the X800M2 is able to play MKV files with Dolby Vision? It is MEL Dolby Vision and one of those MKV's with the Dolby Vision in a single track. In media info app it says HEVC Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible V_MPEGH/ISO/HEVC
Would it show up as Dolby Vision when played on the X800M2? Or would it have to be converted to an M2TS file with the BD file structure to be played as Dolby Vision? Or would there be no functional difference in the quality anyway since it's MEL? Thank you for any help with this as I have been trying to extract the DV layer from the MKV but not having any luck so would like to know if I'm wasting my time.
sw5163
Post by sw5163 » Wed Jul 13, 2022 7:33 am
No, convert FEL to MEL will cause visible quality lose in FEL capable device.
See https://www.avsforum.com/threads/dune-p ... t-60582530
MEL image is 10-bit 4:2:0 subsampling, while FEL is 12-bit 4:2:2, I think.
Real 10-bit RGB or 4:4:4 panel can use dithering algorithm to imitate 12-bit color, so there will be a visible quality lose.
I think most DV compatible TV support MEL mp4 through their internal player.
If you really don't care about FEL, Apple TV or any iOS device is capable of MEL playback.
See around viewtopic.php?p=123899#p123899
I personally use iPad to watch MEL, since its portable and I can watch it on bed. (Yes Im very lazy)
Some people here would disaprove this, but by now, iOS devices can play MEL (iPad pro 12.9 1600-nit) and dolby atmos 7.1 audio (eac3 through AirPods pro spatio audio). See https://developer.dolby.com/platforms/a ... e-support/. If you are as lazy as I am and don't want to spend extra money, this should meet your expectation. But still I would recommend proper FEL capable device and physical 7.1.4 sound system for the most prime watching experience.
bradchad
Post by bradchad » Wed Jul 13, 2022 9:05 am
Sorry to jump in like this.
I am very very new here and I just started using the tools generously provided by RESET_9999. I just wanted to know what is the workflow I should use to convert a MKV, dual layer P7 with TrueHD 7.1 audio, to something that can run natively of my LG C1 (or through Plex to my LG C1), with both Dolby Vision and Atmos. An example would be spider-man NWH.
To my understanding, I need to convert the P7 to a P5 or P8, and convert the TrueHD audio to something like EAC3. I am simply unsure how to get there using the Dovi_tools RESET_9999 put together.
Also, I see these terms fairly often, but I have no clue what ST-DL and DT-DL mean.
Thank you!!
stn17
Post by stn17 » Wed Jul 13, 2022 10:00 am
Isn't zidoo lldv instead of tv-led? As well as dune.
dwalme
Post by dwalme » Wed Jul 13, 2022 11:57 am
Not sure about Dune but Zidoo Z9X does both.
sofakng
Post by sofakng » Wed Jul 13, 2022 2:55 pm
Thanks again so much for the help.
Any advice regarding the Oppo 203 clone (M2910) instead of the X800M2?
sw5163
Post by sw5163 » Wed Jul 13, 2022 6:00 pm
They are command line tools.
See recommendation CX or newer at https://docs.google.com/spreadsheets/d/ ... jymVo/edit
I think almost no tv’s internal player is capable of DV MKV playback.
Do the P7->P8.1 conversion with any tool you like.
I wouldn't recommend converting trueHD, use the ac3 core in the file instead, it’s converted by the filmmaker and keeps director’s intention.
ST-DL refers to single track dual layer FEL file and DT-DL to dual track dual layer FEL.
Dolby Vision is very complicated, you may want to read more post to learn more of this.
Post by RESET_9999 » Wed Jul 13, 2022 6:37 pm
first, edit the bat file with notepad and set tsmuxer.popup=YES and mkvtoolnix.popup=NO
then: 1 - 7 - 2 - 2
dwalme
Post by dwalme » Wed Jul 13, 2022 6:49 pm
I've never used the Oppo clone so I will let others comment.
The nice thing about the X800M2 is that in a pinch you can always throw the disc in and play if you needed to. Say you just received a movie and wanted to watch before ripping.
bradchad
Post by bradchad » Wed Jul 13, 2022 8:53 pm
then: 1 - 7 - 2 - 2
Thank you so much for the detailed response!!
sw5163
Post by sw5163 » Thu Jul 14, 2022 2:31 am
Maybe update the Playback-Devices list?
It's been confirmed Apple TV and iOS devices can play BL+RPU with some conversion.
Or not, if that is considered conflicting to Dolby standards and rules
