I dont know. maybe try the nightly lavfilters ?dvfan wrote: ↑Wed Jul 06, 2022 9:49 pmHello, yes i installed the LAV Filters twice just to be sure. All works, i run madvr and it works, with HDR and everything. I can see the info on screen just fine as well. With all measurements, but when i run the script it always shows error with connecting to LAV Filter - failed.
it's working on my end.
1) MODE.1= HDR10(madVR) or HDR10plus to DoVi maker
2) MODE.2= Batch convert up to 13 HDR10plus videos to DoVi
3) MODE.3= Inject DV from existing measurement file
4) MODE.4= Batch measure a folder with mkv HDR10 files (credit to manni)
5) MODE.5= Back to main menu
Choice? [1,2,3,4,5]?1
* CHOOSE A WORKFLOW *
1) Workflow.1= Convert 1 video + AUTO L5
2) Workflow.2= Convert 1 video + MANUAL L5
3) Workflow.3= Convert 1 video + MANUAL L5 + TrueHD_to_TrueHD.ac3 + DDP_1536kbps
4) Workflow.4= Convert 1 video + MANUAL L5 + TrueHD_to_TrueHD.ac3
5) Workflow.5= Convert 1 video + MANUAL L5 + DDP_1536kbps
6) Workflow.6= Convert 1 video + AUTO L5 + REMOVE HDR10plus (fire stick TV)
7) Workflow.7= Back to main menu
Choice? [1,2,3,4,5,6,7]?1
--This workflow will convert an HDR10 or HDR10plus video to DoVi and set L5 automatically
--The black bars detection may not be perfectly accurate. It's maybe better to measure them manually
Drag and drop your HDR10 or HDR10plus MKV/MP4/TS file and press enter...D:\samples\hdr10.mkv
Do you want to crop RPU... y or n ? (y when HDR10-BL is cropped) and/or press enter...
Measuring the HDR10 video letterbox...
min: 0.0001 cd/m2, max: 1000 cd/m2
Extracting track 0 with the CodecID 'V_MPEGH/ISO/HEVC' to the file 'D:\TEMP\HDR.hevc'. Container format: HEVC/H.265 elementary stream
Progress: 100%
SMPTE ST 2086
HDR10plus metadata not present. Generating DoVi from HDR10 with madVR...
Measuring video file "D:\samples\hdr10.mkv" using D3D11 (native)...
Metadata:
Mastering display luminance: 0.0001/1000, gamut: 0.68 0.32, 0.15 0.06, 0.265 0.69, 0.3127 0.329
MaxCLL: 0, MaxFALL: 0 nits
Measurements:
Frames: 10274, MaxCLL 100%: 623, 99.9%: 598, MaxFALL: 250, AvgFALL: 44, AvgFMLL: 416 nits
Parsing madVR measurement file...
Generating metadata: Profile 8.1 (HDR10)...
Generated metadata for 10274 frames
Done.
EditConfig {
mode: 0,
remove_cmv4: false,
remove_mapping: false,
active_area: Some(
ActiveArea {
crop: false,
drop_l5: None,
presets: Some(
ActiveAreaOffsets {
left: 0,
right: 0,
top: 276,
bottom: 276,
edits: Some(
"all": 0,
remove: None,
duplicate: None,
min_pq: None,
max_pq: None,
level6: None,
level9: None,
level11: None,
Parsing RPU file...
Editing active area offsets...
Final metadata length: 10274
Writing RPU file...
EditConfig {
mode: 0,
remove_cmv4: false,
active_area: None,
remove: None,
duplicate: None,
min_pq: None,
max_pq: None,
level6: Some(
ExtMetadataBlockLevel6 {
max_display_mastering_luminance: 1000,
min_display_mastering_luminance: 1,
max_content_light_level: 0,
max_frame_average_light_level: 0,
level9: None,
level11: None,
Parsing RPU file...
Writing RPU file...
"left": 0
"right": 0
"top": 276
"bottom": 276
MDL.max: 1000
MDL.min: 1
Maxcll: 0
Maxfall: 0
Display P3
injecting RPU-L6-L5.bin ...
Parsing RPU file...
Processing input video for frame order info...
Warning: Input file already has RPUs, they will be replaced.
Rewriting file with interleaved RPU NALs..
"Level1": {
"min_pq": 0,
"max_pq": 2708,
"avg_pq": 1141
"Level5": {
"active_area_left_offset": 0,
"active_area_top_offset": 276,
"active_area_bottom_offset": 276
"Level6": {
"max_content_light_level": 0,
"max_frame_average_light_level": 0
"cmv40_metadata": {
"num_ext_blocks": 3,
"ext_metadata_blocks": [
"Level9": {
"length": 1,
"source_primary_index": 0
"Level11": {
"content_type": 1,
"whitepoint": 0,
"reference_mode_flag": true,
"reserved_byte2": 0,
"reserved_byte3": 0
"Level254": {
"dm_mode": 0,
"dm_version_index": 2
"rpu_data_crc32": 867262424
Parsing RPU file...
Summary:
Frames: 10274
Profile: 8
DM version: 2 (CM v4.x)
Scene/shot count: 177
"The script has completed."
