Just bought a WH16NS60 - wanting to flash it
CrazyWookiee
#1 Post by CrazyWookiee » Fri Jul 01, 2022 11:51 am
It came with 1.03 installed. Looking around, I need to put 1.02 on it. I plan on going with 1.02 MK. Is there a flash tool that works with Win 7 or Linux?
Re: Just bought a WH16NS60 - wanting to flash it
#2 Post by d00zah » Fri Jul 01, 2022 1:05 pm
From the topic SDFtool Flasher:
Here is the old original version of the SDFtool flasher: (works on Win7)
sdftool_flasher.zip
CrazyWookiee
#3 Post by CrazyWookiee » Sat Jul 02, 2022 11:49 am
d00zah wrote: Fri Jul 01, 2022 1:05 pm From the topic SDFtool Flasher:
sdftool_flasher.zip
Thanks. I downloaded the pack that is mentioned here. I assume 1.03 is the latest MK version. I tried using it and 1.02. The flasher acts like everything worked properly. Nothing seems to have changed in MakeMKV though. It still says 1.03 even when I supposedly flash 1.02.
#4 Post by d00zah » Sat Jul 02, 2022 3:47 pm
Does MakeMKV report this?
Firmware type: Original (unpatched) or ... (patched) depending on version
Firmware version: 1.0x
If so, you are good to go.
#5 Post by Billycar11 » Sat Jul 02, 2022 7:16 pm
Enc
CrazyWookiee
#6 Post by CrazyWookiee » Sat Jul 02, 2022 9:47 pm
d00zah wrote: Sat Jul 02, 2022 3:47 pm Does MakeMKV report this?
It does not. Firmware says original. Where you put yes or enabled all say possible with patched firmware.
#7 Post by d00zah » Sun Jul 03, 2022 9:38 am
CrazyWookiee wrote: Sat Jul 02, 2022 9:47 pm It does not. Firmware says original. Where you put yes or enabled all say possible with patched firmware.
Billycar11 wrote: Sat Jul 02, 2022 7:16 pmEnc
In SDFTool, check the 'enc?' box before 'Start'.
CrazyWookiee
#8 Post by CrazyWookiee » Fri Jul 08, 2022 10:44 am
When I try doing it with "enc?" checked, I get an error saying "command produced error code 0x8f056103."
#9 Post by Coopervid » Fri Jul 08, 2022 11:21 am
You should first flash 1.03 MK with "enc". Then - if successful - flash 1.02 in a second step.
CrazyWookiee
#10 Post by CrazyWookiee » Tue Jul 12, 2022 6:44 am
I get the error code no matter what I try doing.
#11 Post by Billycar11 » Tue Jul 12, 2022 6:56 am
CrazyWookiee wrote: Tue Jul 12, 2022 6:44 am I get the error code no matter what I try doing.
you can try my automated flasher its $25 if it works
CrazyWookiee
#12 Post by CrazyWookiee » Thu Jul 14, 2022 10:22 am
I finally got it to work. Forgot I left a disc in the drive and that was causing the error for some reason. I'm now on 1.02. I'm now ripping my first UHD disc. Thanks for the help.
#13 Post by MartyMcNuts » Thu Jul 14, 2022 11:00 am
CrazyWookiee wrote: Thu Jul 14, 2022 10:22 am I finally got it to work. Forgot I left a disc in the drive and that was causing the error for some reason. I'm now on 1.02. I'm now ripping my first UHD disc. Thanks for the help.
I swear people just don't know how to read instructions!! Anyway, glad you got it sorted.
drk9ght1
#14 Post by drk9ght1 » Sun Aug 21, 2022 4:30 pm
I just bought the LG WH16NS60 and it had the 1.03 firmware on it also. I successfully flashed to mk 1.02, but need it to be 1.0.
So i tried flashing directly to 1.0 and when flashing it showed everything went through successfully, but makemkv showed it still as 1.02.
I then read that side loading was a successful way in downgrading and proceeded to flash ASUS-BW-16D1HT-3.10-WM01601-211901041014 (successful 100%),
but makemkv still read 1.02. Rebooted and tried flashing with DE_LG_WH16NS60_1.00 (successful 100%) and checked makemkv status and still it read 1.02.
Not sure what I"m doing wrong if anything? If you could please help or point me in the right direction I'd appreciate it?
#15 Post by Coopervid » Sun Aug 21, 2022 7:25 pm
Once flashed don't check "enc".
