THE_NORTHMAN_UPK2 (impossible to tear)
Thor14
#1 Post by Thor14 » Sat Jul 09, 2022 9:49 am
MKB20_v76_THE_NORTHMAN_UPK2_C97C.tgz
(3.36 MiB) Downloaded 238 times
hello and thanks for everything in advance, I've been trying to rip this disc for several weeks with different tools and it's impossible, this never happened, so I give up and leave information here in case any of the teachers can try it.
Re: THE_NORTHMAN_UPK2 (impossible to tear)
#2 Post by d00zah » Sat Jul 09, 2022 10:14 am
The UHD FAQ is a great place to start... the Hashed Keys section.
Thor14
#3 Post by Thor14 » Sat Jul 09, 2022 10:19 am
My friend, I have already done everything indicated in that thread, even so I will leave information here in case it helps
MKB20_v76_THE_NORTHMAN_UPK2_C97C2.tgz
(3.36 MiB) Downloaded 194 times
(3.36 MiB) Downloaded 193 times
Thor14
#4 Post by Thor14 » Mon Jul 11, 2022 9:37 am
Hello, as it says, I have rented a disk again and here I leave you the log directly from the disk and not from an iso, I hope you can decipher it
(3.36 MiB) Downloaded 200 times
#5 Post by Coopervid » Mon Jul 11, 2022 9:43 am
Email the dump file to svq@makemkv.com
This is the fastest way that your disc will be supported soon.
Thor14
#6 Post by Thor14 » Mon Jul 11, 2022 10:12 am
already sent for the fourth time, I hope you can attend quickly, since today I have to return the rented disc
#7 Post by Coopervid » Mon Jul 11, 2022 12:40 pm
Then you should make a protected ISO so you can decrypt it later. Do you know how to do so?
