THE_NORTHMAN_UPK2 (impossible to tear)
hello and thanks for everything in advance, I've been trying to rip this disc for several weeks with different tools and it's impossible, this never happened, so I give up and leave information here in case any of the teachers can try it.
Re: THE_NORTHMAN_UPK2 (impossible to tear)
The UHD FAQ is a great place to start... the Hashed Keys section.
My friend, I have already done everything indicated in that thread, even so I will leave information here in case it helps
- MKB20_v76_THE_NORTHMAN_UPK2_C97C2.tgz
- (3.36 MiB) Downloaded 360 times
- MKB20_v76_THE_NORTHMAN_UPK2_C97C.tgz
- (3.36 MiB) Downloaded 371 times
Hello, as it says, I have rented a disk again and here I leave you the log directly from the disk and not from an iso, I hope you can decipher it
- (3.36 MiB) Downloaded 362 times
Email the dump file to svq@makemkv.com
This is the fastest way that your disc will be supported soon.
already sent for the fourth time, I hope you can attend quickly, since today I have to return the rented disc
Then you should make a protected ISO so you can decrypt it later. Do you know how to do so?
