Can any one help me?
AirWolf
Post by AirWolf » Sun Jul 10, 2022 12:40 pm
Hi all,
I am useing Make MKV to convert my bluerays and just droping them in to my PLEX media folder are the any pit falls in doing this? :?
I thank you for any input you might have :D
Re: Can any one help me?
Post by Woodstock » Sun Jul 10, 2022 3:32 pm
Put the output files on your plex server. Watch them.
What's more complex than that?
Post by dcoke22 » Mon Jul 11, 2022 4:15 pm
There are some subtleties… For example, some movies have what are called forced subtitles. For example, The Hunt for Red October (1990) has the part near the beginning where the Soviet crew is speaking Russian. Even when you're watching the English soundtrack you want the English subtitles to appear during this part. Those subtitles are the forced subtitles.
MakeMKV has undoubtedly included them in your rip, but it is anyone's guess how they're packaged on the disc. There are no standards and every disc seems a bit different. In any case, there's are flags for that track in the metadata of the .mkv file that should be set properly so that Plex can find the forced subtitle track and turn it on automatically. The flags are 'default' and 'forced'. If those are both set to true then Plex will see that and play it properly.
The mediainfo tool is very helpful for looking at .mkv file metadata.
mkvpropedit (part of the MKVToolNix tools) is very helpful for updating the metadata of a .mkv file.
Furthermore, I like to name things like commentary audio tracks so they show up in a useful way in Plex.
This again is a .mkv file metadata action. You can do it either via naming tracks in MakeMKV before you rip or afterwards using mkvpropedit.
