Audio track not showing up
vyse_the_airpirate
Post by vyse_the_airpirate »
Hello there, I'm trying to rip a DVD but the audio track isn't showing up. It's the 1st disc of a 6 disc box set and this is the only disc that I'm having issue with. The DVD does indeed contains an audio track, and plays well in VLC.
Any idea how I can force MakeMKV to detect the audio track?
Re: Audio track not showing up
Post by mike admin »
This will be "fixed" (by adding a "forced audio detection" on DVD) in the next version, 1.17.1 . It should just work then...
If you are on windows, you may try this intermediate version - https://www.makemkv.com/download/Setup_ ... _nav01.exe
vyse_the_airpirate
mike admin wrote: Fri Jul 08, 2022 6:55 pm If you are on windows, you may try this intermediate version - https://www.makemkv.com/download/Setup_ ... _nav01.exe
Hi mike, the new version isn't detecting the audio track. In fact, it's detecting much less stuff than the standard 1.17.0 version.
vyse_the_airpirate wrote: Sat Jul 09, 2022 12:47 pm Hi mike, the new version isn't detecting the audio track. In fact, it's detecting much less stuff than the standard 1.17.0 version.
Wow. I'd like to see a log file or test dump for this disc then. Please PM or email support@makemkv.com. Thanks!
vyse_the_airpirate
mike admin wrote: Sat Jul 09, 2022 8:02 pm Wow. I'd like to see a log file or test dump for this disc then. Please PM or email support@makemkv.com. Thanks!
Hey Mike, did you have a chance to look into it?
