Drive Firmware not Updating
dinasty23
#1 Post by dinasty23 » Fri Jul 08, 2022 3:37 am
Hi there,
I recently purchased an LG WP50NB40 as a disk drive for my plex server running on a Pop_OS! machine, and I'd like to make it a LibreDrive. According to MakeMkv, this is possible, and I've followed these Linux forums, and as far as I can tell have successfully flashed HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin to the drive using
sdftool -d /dev/sr1 rawflash -i HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
. The output from my terminal has been added as an attachment. However, when I go into MakeMkv after this, it states that Libre Drive is still not enabled. I've tried rebuilding MakeMkv from source post patch, as well as attempting to patch with HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin and HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin. Any help would be greatly appreciated!
Re: Drive Firmware not Updating
#2 Post by Billycar11 » Fri Jul 08, 2022 8:12 am
dinasty23 wrote: Fri Jul 08, 2022 3:37 am Hi there,
post your full drive info and
read the guide
you may have encrypted fw and need enc and you need to use HBD fw to convert to bp 60
dinasty23
#3 Post by dinasty23 » Fri Jul 08, 2022 1:14 pm
Here is my full drive info:
What do you mean by "use HBD fw to convert to bp 60"? Thanks for the quick response!
#4 Post by Billycar11 » Fri Jul 08, 2022 9:53 pm
This part of guide is likely relavant BP50NB40-NB50-1.03MK with enc > BP50NB40-NB50-1.03MK with bootloader/full flash > BP60NB10 1.00_HBD from Marty download/file.php?id=2143
if using command line add "full" after rawflash
dinasty23
#5 Post by dinasty23 » Sat Jul 09, 2022 1:26 am
The enc keyword did the trick! Thanks for your help.
