Unable to read DVD for region code after flashed to MK Firmware
soild79
Post by soild79 » Wed Jul 06, 2022 1:10 pm
Hi All
Need you advise on how to really flashed my Buffalo Slim Dvd External Drive to be region free.
I have used the SDFtool to flash and it's seem to completed successfully and from the MKV program it displayed DVD all region: Yes but i still can't read my DVD
Previous i have used the HL-DT-ST-BD-RE_BU40N-BN12-0M01001-211905141415 to flash.
DVD Drive.png (93.17 KiB) Viewed 5482 times
Re: Unable to read DVD for region code after flashed to MK Firmware
Post by Billycar11 » Wed Jul 06, 2022 10:41 pm
Try letting windows load the DVD first then open makemkv
soild79
Post by soild79 » Thu Jul 07, 2022 2:01 pm
The disc is loaded on the windows side.
Still no luck, it is stuck at this scanning process and the drive went to idle state after some time.
Btw i also can't play the DVD using VLC but i have tried to use a trial DVD rip software that allow all region read and it seem fine.
This mean that my All Region is not really working or enable.
Post by Billycar11 » Thu Jul 07, 2022 2:32 pm
Try using both USB cables if your not already
soild79
Post by soild79 » Sun Jul 10, 2022 12:52 pm
Does not seem to work also
