Casino Royale & SPECTRE UHD Disc Errors
spbarney
Post by spbarney » Mon Jul 04, 2022 2:12 pm
Hey y'all,
Long time lurker, first time poster.
I've been slowly building a Plex library thanks to all the information in this forum. However running into an issue when trying to burn two of my UHD discs, and it only seems to happen with these discs!
When trying to make a mkv copy of either Casino Royale or Spectre from the 4-disc Daniel Craig 007 collection, I run into errors like below:
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00014.m2ts' at offset '0'
Failed to save title 4 to file /Users/Shawn/Movies/Casino Royale/Casino Royale_t04.mkv
This is when I just select one file or all the files in the disc. I've cleaned the disc repeatedly, tried isolating specific m2ts files, and still get the errors like above.
Has anyone run into this issue before?
Here is my current equipment and software:
LG WH16NS40, flashed to appear as LG WH16NS60 1.02
Housed in NST-536S3-BK
Running makeMKV Beta 1.17.0
MacOS Montery 12.4
apophis906
Re: Casino Royale & SPECTRE UHD Disc Errors
Post by apophis906 » Mon Jul 04, 2022 4:52 pm
I was ripping Captain Marvel again and got them around the 37gb mark. Then got it with Infinity War a bit into it and then Ant Man & Wasp at the start. I got the error on three different drives on two different PC's. I gave it a try on a third PC that just happened to have 16.5 still installed and it ripped Ant Man & Wasp fine. I rolled back 17.0 on the other two and those all ripped with no errors.
It could be something to do with the changes to how it handles structure protection that was improved in 17.0.
*edit
Also I noticed that when it would get to the point of the error the program would go to "not responding" and freeze up for a bit and then it would flood with lots of errors.
spbarney
Post by spbarney » Thu Jul 07, 2022 1:13 pm
That's a lot better than me!
I ended up going to 1.16.4, but I still ran into the same issue. This time I let it continue until it stopped and... Still running into weird errors, which I'll show below.
Might it be an issue with my drive itself? Just for some reason not reading those two specific UHD discs?
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00014.m2ts' at offset '11487805440'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk5' at offset '11487805440'
Failed to save title 0 to file /Users/Shawn/Movies/Casino Royale/Casino Royale_t00.mkv
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00013.m2ts' at offset '7471104'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk5' at offset '7471104'
Failed to save title 1 to file /Users/Shawn/Movies/Casino Royale/Casino Royale_t01.mkv
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading '/BDMV/STREAM/00014.m2ts' at offset '522240'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk5' at offset '522240'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00014.m2ts' at offset '522240'
Failed to save title 2 to file /Users/Shawn/Movies/Casino Royale/Casino Royale_t02.mkv
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '0'
Failed to save title 3 to file /Users/Shawn/Movies/Casino Royale/Casino Royale_t03.mkv
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00038.m2ts' at offset '0'
Failed to save title 5 to file /Users/Shawn/Movies/Casino Royale/Casino Royale_t05.mkv
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00013.m2ts' at offset '0'
Failed to save title 6 to file /Users/Shawn/Movies/Casino Royale/Casino Royale_t06.mkv
Failed to save title 7 to file /Users/Shawn/Movies/Casino Royale/Casino Royale_t07.mkv
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '0'
Failed to save title 8 to file /Users/Shawn/Movies/Casino Royale/Casino Royale_t08.mkv
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00062.m2ts' at offset '1044480'
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading '/BDMV/STREAM/00062.m2ts' at offset '1179648'
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading '/BDMV/STREAM/00062.m2ts' at offset '1308672'
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading '/BDMV/STREAM/00062.m2ts' at offset '1437696'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00062.m2ts' at offset '1505280'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00062.m2ts' at offset '1572864'
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading '/BDMV/STREAM/00062.m2ts' at offset '1701888'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00061.m2ts' at offset '11206656'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk5' at offset '11206656'
Failed to save title 10 to file /Users/Shawn/Movies/Casino Royale/Casino Royale_t10.mkv
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00060.m2ts' at offset '0'
Failed to save title 11 to file /Users/Shawn/Movies/Casino Royale/Casino Royale_t11.mkv
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00043.m2ts' at offset '0'
Failed to save title 12 to file /Users/Shawn/Movies/Casino Royale/Casino Royale_t12.mkv
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00055.m2ts' at offset '0'
Failed to save title 13 to file /Users/Shawn/Movies/Casino Royale/Casino Royale_t13.mkv
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00044.m2ts' at offset '0'
Failed to save title 14 to file /Users/Shawn/Movies/Casino Royale/Casino Royale_t14.mkv
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '0'
Failed to save title 15 to file /Users/Shawn/Movies/Casino Royale/Casino Royale_t15.mkv
Post by d00zah » Thu Jul 07, 2022 2:40 pm
This is usually the mark of an under-powered external drive resetting under load. Try.
- Using BOTH of the USB Y-cable plugs
- Using a different USB port(s).
- Using an externally powered USB hub.
- If powered external enclosure, check power connection (supply?).
charnathan
Post by charnathan » Sun Jul 10, 2022 7:26 pm
It could just be bad discs from the factory.
I had the same issue with Spectre late last year when I bought the "old" Daniel Craig Collection (the one without No Time To Die).
I went through 3 different box sets and couldn't back it up. Ended up having to buy Spectre separately and it was able to back-up successfully.
audiom3
Post by audiom3 » Sun Jul 10, 2022 7:51 pm
Yeah I am betting bad discs too. I've had weird things happen on rip failures. Swap out for another disc/copy and they always rip fine second one through. I have all 4k movies mentioned in this thread and all ripped without issues. I use an internal LG 14NS40 for reference w/ v1.03 (16NS60 firmware) flashed.
