DVD not copying
L4UoA
DVD not copying
Post by L4UoA » Thu Jun 30, 2022 11:50 pm
I just purchased "Fantastic Beasts The Secrets of Dumbledore" and while the computer recognizes the disk, MakeMKV recognizes the disk but hangs during opening the disk. Just downloaded the new version 1.17.0
Re: DVD not copying
Post by Woodstock » Fri Jul 01, 2022 12:12 am
"Hangs during opening" is suspicious. Is it hanging while loading the disk, or after you loaded it and started extracting? They mean different things.
mpking
Re: DVD not copying
Post by mpking » Fri Jul 01, 2022 3:44 am
First... Woodstock, the FAQ in your signature comes back Server 500 error. But I think I figured out the Advanced logging.
Second. I'm having the same problem as L4UoA. Same DVD, Fantastic Beasts The Secrets of Dumbledore
Program just hangs while "Opening Disc"
Says Title id: #37
Current cell: 1:1/1
Current VOBU: 0
The elapsed time just keeps counting up, as well as the remaining time.
Logfile is really short, doesn't seem to be helpful:
Debug log started at Fri Jul 01 03:38:24 2022 , written by MakeMKV v1.17.0 win(x64-release)
001005:0000 MakeMKV v1.17.0 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\Mike/MakeMKV_log.txt
No  SDF v08d: ASUS_SBW-06C1S-U_C101_0010069EPV1
No auto SDF v08d: ASUS_SBW-06C1S-U_C101_0010069EPV1
DEBUG: Code 0 at ao[X*Bcvc?%qM,+:D:121264142
DEBUG: Code 0 at ]M#HK*gdYnz32A^n:213136769
DEBUG: Code 3 at 4^=z<Kvs'aZ>Dxn+E!~8apE::29395310
SDF id v08d: ASUS_SBW-06C1S-U_C101_0010069EPV1
Launching C:\Program Files (x86)\MakeMKV\mmgplsrv64.exe
ock913
Re: DVD not copying
Post by ock913 » Fri Jul 01, 2022 12:01 pm
Hello ....... although a registered user of MakeMKV since 2016, I have never really had many issues that I couldnt find an answer to, but I am having this one as well. Fantastic Beasts: The Secrets of Dumbledore either has a new encryption method or something is causing MakeMKV to hang during loading. I let it run for nearly 30 minutes and never advanced any further and the estimated completion timer just continued to get higher and higher with no progress.
Re: DVD not copying
Post by dcoke22 » Sat Jul 02, 2022 11:22 pm
MakeMKV 1.17.0 has a new way it processes DVDs: DVD opening modes - CellWalk, CellTrim, CellFull
What happens if you configure MakeMKV to use a different opening mode for this DVD? I think the CellTrim mode would be what MakeMKV was doing in version 1.16.7.
Abflieger
Re: DVD not copying
Post by Abflieger » Sun Jul 03, 2022 5:23 pm
Hello!
I had the same issue with same DVD with same version of MKV.
After reading this post, I change my preference to CellTrim
and I was able to process the DVD.
I did some check on the final export and everything seems OK.
Hope that help :)
L4UoA
Re: DVD not copying
Post by L4UoA » Tue Jul 05, 2022 2:50 pm
I did the same as others, changed to CellTrim and it seems to have created a good backup. However, don't understand why MakeMKV would not recognize all of this without intervention.
ock913
Re: DVD not copying
Post by ock913 » Tue Jul 05, 2022 7:45 pm
Changing setting to CellTrim resolved the issue for me as well.
Saneblade
Re: DVD not copying
Post by Saneblade » Wed Jul 06, 2022 12:16 am
I love this community. Was about to wait forever for this disc to open when I decided to check. Changed to CellTrim and it opened almost immediately!
Re: DVD not copying
Post by mike admin » Wed Jul 06, 2022 5:55 am
This is a bug in 1.17.0 . The program should never "hang" in scan phase.
Anyone who has this disc, please PM or write to support@makemkv.com - I'd like to get some specific log file.
goofnsox
Re: DVD not copying
Post by goofnsox » Wed Jul 06, 2022 1:38 pm
I'm having the same issue with Fantastic Beasts as others posting, and thanks for figuring out the change to Celltrim!. The other issue that I was going to bring up is that I can't stop the action from the cancel (stop hand toggle box). The prompt box does come up to verify if I want to cancel though doesn't matter if I select yes or no it doesn't do anything. Only way to stop it is to close of application.
Re: DVD not copying
Post by mike admin » Thu Jul 07, 2022 8:18 am
Please, please, please if someone has this disc, and is willing to help, do contact me via PM or at support@makemkv.com . Thanks!
drxenos
Re: DVD not copying
Post by drxenos » Mon Jul 11, 2022 3:12 pm
mike admin wrote: Thu Jul 07, 2022 8:18 am Please, please, please if someone has this disc, and is willing to help, do contact me via PM or at support@makemkv.com . Thanks!
If you haven't gotten any responses, I have this disc and can try to assist you.
Whitdjinn
Re: DVD not copying
Post by Whitdjinn » Mon Jul 11, 2022 5:28 pm
Just registered to post this....
I have a BluRay copy and changing the DVD protection preference did not help me...Is there another method I can try to change something up in order to get it to read?
Re: DVD not copying
Post by Woodstock » Mon Jul 11, 2022 6:06 pm
You're having an issue with the BLURAY routine and the DVD routine didn't help? Sounds suspiciously logical to me...
Note that most drives use different lasers for DVD vs. Bluray, and there are other hardware differences.
