Unable to read DVD for region code after flashed to MK Firmware
Re: Unable to read DVD for region code after flashed to MK Firmware
Try letting windows load the DVD first then open makemkv
soild79 wrote: Thu Jul 07, 2022 2:01 pm The disc is loaded on the windows side.
Still no luck, it is stuck at this scanning process and the drive went to idle state after some time.
Btw i also can't play the DVD using VLC but i have tried to use a trial DVD rip software that allow all region read and it seem fine.
This mean that my All Region is not really working or enable.
Try using both USB cables if your not already
