JoseTheBae
#6796 Post by JoseTheBae » Wed Jul 06, 2022 7:44 pm
RESET_9999 wrote:
Tue Jul 05, 2022 6:43 pm
JoseTheBae wrote:
Tue Jul 05, 2022 3:46 pm
What Plex Client version was this on? I can't get Plex to output lossless audio on my Ugoos AM6B Plus.
no particular version. I was able to make it work about 3-4 times and it just seem to work randomly.
Do you still have an Ugoos AM6B Plus? I am looking for a Kodi build that processes the Full Enhancement Layer. I have tried several different builds. Only the modified ExoPlayer APK processes the FEL, but it stutters so much that it isn't really watchable. Do you know a Kodi build that definitely processes the FEL?
#6797 Post by RESET_9999 » Wed Jul 06, 2022 7:55 pm
nop, I sold my ugoos a long time ago. I was using the Kodinerds built and it processed the FEL but there was micro stuttering and sometimes the movie would just freeze.
In my opinion, you are wasting your time/money with this device. If you want stable FEL playback get the Sony x700 or x800m2.
JoseTheBae
#6798 Post by JoseTheBae » Wed Jul 06, 2022 8:24 pm
Oh, I see. It's so annoying, because I feel so close to achieving complete Dolby Vision playback. Plex can process the FEL and play it smoothly, but it doesn't have lossless audio on this device. As for Kodi, I have Dolby Vision playing smoothly with lossless audio on Fandango's build, just without the FEL. If only Plex got to supporting lossless audio on this device; then this would finally provide reliable playback for everything.
dvfan
#6799 Post by dvfan » Wed Jul 06, 2022 8:36 pm
I'm new to the forum and i'm trying to use the script but getting a lot of path errors and LAV Filter can't be loaded issues.
I'm using Windows 11 Pro.
This are the errors i currently get when trying to create DoVi from HDR10.
I tried option 4-4
And also option 7-1-6
Always same errors with paths and LAV Filter as follows:
F:\TEMP\THD.mkv: No such file or directory
Error: Unknown mode 'F:\TEMP\_AC3.mkv'.
SMPTE ST 2086
Connecting LAV Splitter Source to LAV Video Decoder failed.
Parsing madVR measurement file...
Error: System can't find the file specified. (os error 2)
Also other errors:
a02 Processed audio track: max 24 bits, average 19 bits, most common 16 bits.
Video track 1 contains 1303 frames.
eac3to processing took 2 seconds.
Done.
mkvmerge v67.0.0 ('Under Stars') 64-bit
Error: The file 'F:\TEMP\en.thd' could not be opened for reading: open file error.
Error: The file 'F:\TEMP\en.dtsma' could not be opened for reading: open file error.
ffmpeg version 5.0.1-full_build-www.gyan.dev Copyright (c) 2000-2022 the FFmpeg developers
  built with gcc 11.2.0 (Rev7, Built by MSYS2 project)
#6800 Post by RESET_9999 » Wed Jul 06, 2022 9:35 pm
Hi, did you install lavfilters?
https://www.videohelp.com/software/LAV-Filters
also dont forget to go in the tools/madvr folder and click (with admin rights) on the install.bat
dvfan
#6801 Post by dvfan » Wed Jul 06, 2022 9:49 pm
Hello, yes i installed the LAV Filters twice just to be sure. All works, i run madvr and it works, with HDR and everything. I can see the info on screen just fine as well. With all measurements, but when i run the script it always shows error with connecting to LAV Filter - failed.
Choice? [1,2,3,4,5]?1
                                         * CHOOSE A WORKFLOW *
1) Workflow.1= Convert 1 video + AUTO L5
2) Workflow.2= Convert 1 video + MANUAL L5
3) Workflow.3= Convert 1 video + MANUAL L5 + TrueHD_to_TrueHD.ac3 + DDP_1536kbps
4) Workflow.4= Convert 1 video + MANUAL L5 + TrueHD_to_TrueHD.ac3
5) Workflow.5= Convert 1 video + MANUAL L5 + DDP_1536kbps
6) Workflow.6= Convert 1 video + AUTO L5 + REMOVE HDR10plus (fire stick TV)
7) Workflow.7= Back to main menu
Choice? [1,2,3,4,5,6,7]?1
Folder Already exists F:\TEMP\.
--This workflow will convert an HDR10 or HDR10plus video to DoVi and set L5 automatically
--The black bars detection may not be perfectly accurate. It's maybe better to measure them manually
Drag and drop your HDR10 or HDR10plus MKV/MP4/TS file and press enter...F:\DoVi_Scripts\test1.mkv
Do you want to crop RPU... y or n ? (y when HDR10-BL is cropped) and/or press enter...n
Measuring the HDR10 video letterbox...
min: 0.0050 cd/m2, max: 1200 cd/m2
Extracting track 0 with the CodecID 'V_MPEGH/ISO/HEVC' to the file 'F:\TEMP\HDR.hevc'. Container format: HEVC/H.265 elementary stream
Progress: 100%
SMPTE ST 2086
HDR10plus metadata not present. Generating DoVi from HDR10 with madVR...
[b]Connecting LAV Splitter Source to LAV Video Decoder failed.[/b]
Error: System can't find the file specified (os error 2)
#6802 Post by RESET_9999 » Wed Jul 06, 2022 10:22 pm
I dont know. maybe try the nightly lavfilters ?
it's working on my end.
1) MODE.1= HDR10(madVR) or HDR10plus to DoVi maker
2) MODE.2= Batch convert up to 13 HDR10plus videos to DoVi
3) MODE.3= Inject DV from existing measurement file
4) MODE.4= Batch measure a folder with mkv HDR10 files (credit to manni)
5) MODE.5= Back to main menu
Drag and drop your HDR10 or HDR10plus MKV/MP4/TS file and press enter...D:\samples\hdr10.mkv
min: 0.0001 cd/m2, max: 1000 cd/m2
Extracting track 0 with the CodecID 'V_MPEGH/ISO/HEVC' to the file 'D:\TEMP\HDR.hevc'. Container format: HEVC/H.265 elementary stream
Progress: 100%
SMPTE ST 2086
Measuring video file "D:\samples\hdr10.mkv" using D3D11 (native)...
Metadata:
  Mastering display luminance: 0.0001/1000, gamut: 0.68 0.32, 0.15 0.06, 0.265 0.69, 0.3127 0.329
  MaxCLL: 0, MaxFALL: 0 nits
Measurements:
  Frames: 10274, MaxCLL 100%: 623, 99.9%: 598, MaxFALL: 250, AvgFALL: 44, AvgFMLL: 416 nits
Generating metadata: Profile 8.1 (HDR10)...
Generated metadata for 10274 frames
Done.
EditConfig {
    mode: 0,
    remove_cmv4: false,
    remove_mapping: false,
    active_area: Some(
        ActiveArea {
            crop: false,
            drop_l5: None,
            presets: Some(
                    ActiveAreaOffsets {
                        left: 0,
                        right: 0,
                        top: 276,
                        bottom: 276,
            edits: Some(
                    "all": 0,
    remove: None,
    duplicate: None,
    min_pq: None,
    max_pq: None,
    level6: None,
    level9: None,
    level11: None,
Parsing RPU file...
Editing active area offsets...
Final metadata length: 10274
Writing RPU file...
EditConfig {
    mode: 0,
    remove_cmv4: false,
    active_area: None,
    remove: None,
    duplicate: None,
    min_pq: None,
    max_pq: None,
    level6: Some(
        ExtMetadataBlockLevel6 {
            max_display_mastering_luminance: 1000,
            min_display_mastering_luminance: 1,
            max_content_light_level: 0,
            max_frame_average_light_level: 0,
    level9: None,
    level11: None,
Parsing RPU file...
Writing RPU file...
"left": 0
"right": 0
"top": 276
"bottom": 276
MDL.max: 1000
MDL.min: 1
Maxcll: 0
Maxfall: 0
Display P3
injecting RPU-L6-L5.bin ...
Parsing RPU file...
Processing input video for frame order info...
Warning: Input file already has RPUs, they will be replaced.
Rewriting file with interleaved RPU NALs..
          "Level1": {
            "min_pq": 0,
            "max_pq": 2708,
            "avg_pq": 1141
          "Level5": {
            "active_area_left_offset": 0,
            "active_area_top_offset": 276,
            "active_area_bottom_offset": 276
          "Level6": {
            "max_content_light_level": 0,
            "max_frame_average_light_level": 0
    "cmv40_metadata": {
      "num_ext_blocks": 3,
      "ext_metadata_blocks": [
          "Level9": {
            "length": 1,
            "source_primary_index": 0
          "Level11": {
            "content_type": 1,
            "whitepoint": 0,
            "reference_mode_flag": true,
            "reserved_byte2": 0,
            "reserved_byte3": 0
          "Level254": {
            "dm_mode": 0,
            "dm_version_index": 2
  "rpu_data_crc32": 867262424
Parsing RPU file...
Summary:
  Frames: 10274
  Profile: 8
  DM version: 2 (CM v4.x)
  Scene/shot count: 177
"The script has completed."
dvfan
#6803 Post by dvfan » Thu Jul 07, 2022 4:07 am
Progress: 100%
SMPTE ST 2086
Metadata:
Measurements:
Done.
EditConfig {
    mode: 0,
    remove_cmv4: false,
    active_area: Some(
        ActiveArea {
            crop: false,
            drop_l5: None,
            presets: Some(
                    ActiveAreaOffsets {
                        left: 0,
                        right: 0,
                        top: 276,
                        bottom: 276,
            edits: Some(
                    "all": 0,
    remove: None,
    duplicate: None,
    min_pq: None,
    max_pq: None,
    level6: None,
    level9: None,
    level11: None,
Parsing RPU file...
Writing RPU file...
EditConfig {
    mode: 0,
    remove_cmv4: false,
    active_area: None,
    remove: None,
    duplicate: None,
    min_pq: None,
    max_pq: None,
    level6: Some(
    level9: None,
    level11: None,
Parsing RPU file...
Writing RPU file...
"left": 0
"right": 0
"top": 276
"bottom": 276
MDL.max: 1000
MDL.min: 1
Maxcll: 0
Maxfall: 0
Display P3
Parsing RPU file...
          "Level1": {
            "min_pq": 0,
            "max_pq": 2708,
            "avg_pq": 1141
          "Level5": {
          "Level6": {
    "cmv40_metadata": {
          "Level9": {
            "length": 1,
          "Level11": {
            "content_type": 1,
            "whitepoint": 0,
            "reserved_byte3": 0
          "Level254": {
            "dm_mode": 0,
Parsing RPU file...
Summary:
  Frames: 10274
  Profile: 8
Hello, i installed the folder into the C:\ instead. It was on F drive before.
Now it worked, somehow it had issues with other driver rather than system drive.
I have a question, is there any way to make the resulting MKV file to show the mastering display luminance/MaxFALL/MaxCLL and color mastering metadata , like when watching with MadVR and you hit Ctrl-F to show info? now it shows only BT. 2020 primaries and BT. 2020 color, nothing else there. It should show the nits mastering followed by the color mastering. Like: 1000 nits HDR - BT. 2020 > DCI-P3 .....
#6804 Post by RESET_9999 » Thu Jul 07, 2022 12:37 pm
I'm not sure I understand but, the script cannot change/remove the static HDR10 metadata of the resulting MKV.
dvfan
#6805 Post by dvfan » Thu Jul 07, 2022 4:12 pm
Yes, it's just the Metadata for the video track. Which in this case would be inside the DV Profile 8.
This is an example so you can understand.
Spider-Man NWH Dolby Vision Profile 8 - MadVR On-Screen INFO:
It shows HDR 9978 nits, since the metadata is properly injected:
You see the Mastering Display numbers at the bottom.
But this is how it ends up when using the Script ( From HDR10 video, which includes this metadata information, but it goes away in the resulting MKV with DV Profile 8 ) :
https://i.imgur.com/3XhJntC.jpg
You can check at the bottom the Mastering Display information metadata is lost.
I've always did this by additional commands to the MKVToolNixGUI. Though if i add these additional commands when muxing the DV Profile 8, it will show duplicate HDR10 metadata.
Like for example MediaInfo shows HDR10/HDR10
And in the detailed information it shows the added metadata for Mastering Display Nits/MaxFall/MaxCLL and Color "P3" though in MadVR won't show up.
Looks like this works kinda different when doing Dolby Vision muxing. It may be added in a future update for the muxing tools used.
#6806 Post by RESET_9999 » Fri Jul 08, 2022 1:11 am
The script will not change/remove the original static hdr10. Custom metadata with mkvmerge cli is another story and I don't really care about it because I use TS container and those custom metadata are lost anyway when muxed in tsmuxer (and probably in the mp4muxer too) and there's nothing I can do about it. Plus it doesnt matter in DV.
my SM no way home using the script... clearly your picture isn't right .. even chroma type 2 is different... level 6.1 ? whatever you did to split that file broke it.
Video
Duration                                 : 2 h 28 min
Bit rate                                 : 55.9 Mb/s
Bits/(Pixel*Frame)                       : 0.281
Stream size                              : 57.8 GiB (92%)
Mastering display color primaries        : BT.2020
Maximum Content Light Level              : 9978 cd/m2
Maximum Frame-Average Light Level        : 867 cd/m2
Donpoku
#6807 Post by Donpoku » Fri Jul 08, 2022 10:19 am
spider-man nwm is Dve 07.06, why change it to 08.06?
#6808 Post by RESET_9999 » Fri Jul 08, 2022 10:42 am
I convert all the MEL movie to P8 so i can watch it anywhere ( TV internal player included). P7 is only useful for FEL.
thetoad
#6809 Post by thetoad » Mon Jul 11, 2022 4:56 pm
quietvoid wrote:
Fri Jul 01, 2022 12:44 pm
thetoad wrote:
Fri Jul 01, 2022 7:54 am
Q, has there been any work done for colorspace conversion for DV profile 5 to HDR10 or SDR? There's plenty of work on tonemapping HDR10 to SDR, but wondering about for DV content on non DV devices.
Of course, it has been supported in libplacebo and mpv for a while now.
Also, Jellyfin has beta support for real time transcoding: https://www.reddit.com/r/jellyfin/comme ... is_coming/
how well does this work on linux? i.e. would the same gemini lake CPUs that can tonemap HDR10 to SDR also be able to handle DV to SDR? I'm also wondering about DV to HDR10, the link only says sdr)
thetoad
#6810 Post by thetoad » Mon Jul 11, 2022 4:58 pm
JoseTheBae wrote:
Tue Jul 05, 2022 12:07 am
Is there some trick to enabling lossless audio in Plex on the Ugoos AM6B Plus? Lossless audio works in Kodi. Oddly, the 32-bit Kodinerds build seems to discard the Full Enhancement Layer in Dolby Vision, even though Plex plays it perfectly. If I can just get lossless audio working in Plex, I will finally achieve full Dolby Vision (FEL) playback.
what plays the FEL? All I've heard is things that "work" with FEL play the MEL and ignore the FEL. so they play, but they don't play the full dolby vision experience. has this actually changed?
