DVD ISO backup not possible on two discs
Ezatoka
Post by Ezatoka » Mon Jul 04, 2022 4:26 pm
Hey mike,
I have two DVD discs, where I cannot create an ISO out of them. They both have a structure protection.
Disc 1:
Debug log started at Mon Jul 04 13:00:02 2022 , written by MakeMKV v1.17.0 win(x64-release)
001005:0000 MakeMKV v1.17.0 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\Ezatoka/MakeMKV_log.txt
DEBUG: Code 3 at 4^=z<Kvs'aZ>Dxn+E!~8apE::29395310
SDF  v08d: ASUS_BW-16D1HT_3.10_211901041014_KLZL1BF2149
SDFW: SET_SPEED Asked=5120 Selected=5632 MSV=0x04
001011:0000 Using LibreDrive mode (v06.3 id=0FA242DD4D0B)
SDFW: SET_SPEED Asked=5120 Selected=8448 MSV=0x06
005072:0000 Backing up disc into folder "file://G:\DVD\redo\Die unendliche Geschichte\DVDVolume.iso"
DEBUG: Code 1 at (5/?c{%Rv{z~wFC5':121263199
DEBUG: Code 20 at (5/?c{%Rv{z~wFC5':121263199
Launching C:\apps\backup\MakeMKV\mmgplsrv64.exe
SDFW: SET_SPEED Asked=101376 Selected=22272 MSV=0x10
001003:0020 DEBUG: Code 100864261 at ]M#HK*gdYnz32A^n:29403291
001003:0020 DEBUG: Code 100864261 at i&6'A,$;;63WHq {:213130559
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE ASUS BW-16D1HT 3.10 KLZL1BF2149' at offset '1468416'
001003:0020 DEBUG: Code 0 at Cp94d'<:ukN$`:fVq8mN:29397909
005069:0080 Backup failed
005080:0204 Backup failed.
Application exited at Mon Jul 04 13:05:40 2022
Disc 2:
Debug log started at Mon Jul 04 16:07:40 2022 , written by MakeMKV v1.17.0 win(x64-release)
005072:0000 Backing up disc into folder "file://G:\DVD\redo\Werner\5. Eiskalt\DVDVolume.iso"
001003:0020 DEBUG: Code 100941314 at ]M#HK*gdYnz32A^n:29403291
001003:0020 DEBUG: Code 100941314 at i&6'A,$;;63WHq {:213130559
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE ASUS BW-16D1HT 3.10 KLZL1BF2149' at offset '1456128'
Application exited at Mon Jul 04 16:13:21 2022
What could be the problem here? I redid like 40 ISOs of DVDs with structure protection and those two are the only ones having a problem. I do have ISOs of both discs created with another tool (DiscImageCreator). If I mount these into a virtual drive and try to make an ISO then with MakeMKV I also get errors. So maybe you could recreate the problem with those ISOs? I cleaned both discs and tried it several times to create a backup.
