LG BP60NB10 1.02 FW Rev. and hope about working with MakeMKV UHD decryption
Hello to all members and staff, sorry about my bad english and congratulations about the great tools and site.
This is my 1st post, I decided to place it here since MakeMKV analysis made me hopeful of being mine a possibly LibreDrive though not completely sure.
So I post the results below:
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIKYVK5QD0038
Firmware date: 2120-05-07 09:35
Highest AACS version: 61
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Disc Information
Label: ASSASSINS CREED
Timestamp: 2017-02-01 12:18:06
Data capacity: 51.90 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Could someone give some advise about what I can expect from this drive regarding UHD ripping?
can I use some of the tools to make it work? Thanks a lot in advance
Revision: 1.02
Disc Information
Number of layers: 2
Re: LG BP60NB10 1.02 FW Rev. and hope about working with MakeMKV UHD decryption
You can rip uhd with that drive after you flash it flash it to BP60NB10 1.02mk with the enc option or checked
Thanks for the prompt reply!
I guess I'm downloading things someplace else or ignore right usage I saw a simple GUI that selects the firmware and the burner, no more options, got error number 5
I feel closer but need a bit more of your kind help.
Thanks again.
Thanks again.
Follow my guide for enc firmware you must use makemkvs built in flasher or something that hooks in to it like sdf tool
I also offer self flash kits that all you do is run it and it works
Get the flasher from hereCarlEHL wrote: Tue Oct 13, 2020 9:09 pm Thanks for the prompt reply!
Thanks again.
https://www.makemkv.com/forum/viewtopic ... 16&t=22896
Morpheus2769
Can someone Please help me and tell me if I'm using the latest firmware version for the LG BP60NB10 1.00 My drive was orignally just a regular bluray burner but i flashed it so i can read and burn 4k's if there is an upgrade to reflash the drive can someone point me in the right direction where to get the firmware thank you
Leave itMorpheus2769 wrote: Sat Jul 02, 2022 4:23 pm Can someone Please help me and tell me if I'm using the latest firmware version for the LG BP60NB10 1.00 My drive was orignally just a regular bluray burner but i flashed it so i can read and burn 4k's if there is an upgrade to reflash the drive can someone point me in the right direction where to get the firmware thank you
Catalyst_Syndrome
Hey all, first time posting here as I am about to start diving in. I am having trouble locating the proper FW to get me to 1.02mk for my BP60NB10. Currently sitting at factory FW, I have about a month to return this drive if I can get it to downgrade, but I watched the video with CMD (admin) ran that with the .bin file from the main UHD drive post. file name: DE_LG_BP50NB40" then realized I was off base.
Downloaded the SDF GUI and cannot seem to locate the proper files. Thanks everyone.
see guide below and all you need fw packCatalyst_Syndrome wrote: Mon May 15, 2023 10:57 pm Hey all, first time posting here as I am about to start diving in. I am having trouble locating the proper FW to get me to 1.02mk for my BP60NB10. Currently sitting at factory FW, I have about a month to return this drive if I can get it to downgrade, but I watched the video with CMD (admin) ran that with the .bin file from the main UHD drive post. file name: DE_LG_BP50NB40" then realized I was off base.
