sw5163
Post
by sw5163 » Mon Jun 27, 2022 11:04 pm
Manixx2020beyound wrote: ↑Mon Jun 27, 2022 8:39 pm
Stream it from Mac m1 to Apple TV
Stream it form pc to Apple TV works
Sorry to bother, but could you please tell me how did you stream video from pc(windows?) to Apple?
Im currently using file sharing through SMB, but I don't know if there is a better way.
Post
by Manixx2020beyound » Mon Jun 27, 2022 11:17 pm
sw5163 wrote: ↑Mon Jun 27, 2022 11:04 pm
Infuse
Plex
sw5163
Post
by sw5163 » Tue Jun 28, 2022 1:54 am
Manixx2020beyound wrote: ↑Mon Jun 27, 2022 11:17 pm
Infuse
Plex
okay, I can't even download plex in China, lol.
Thanks anyway.
sw5163 on Tue Jun 28, 2022 6:04 am, edited 1 time in total.
evilmatcher
Post
by evilmatcher » Tue Jun 28, 2022 5:34 am
dwalme wrote: ↑Sun Jun 26, 2022 4:36 pm
I just recently did the same thing and I tested my copy with my X800M2 after I read this. I have a silent core and have no issues with TrueHD/Atmos playing properly.
I have tried with the copies I made last week of Back to the Future 1 + 2 with the same TS-muxer version from the DOVI-scripts (Feb 22) as i did last week. When i make a new TS-version of those backups it also fails - no sound on the x800m2. When I play all the ones currently on my NAS on the x800m2, all of them works. When using the Feb 22 TS-muxer version i now get an error message stating "Warning: PGS might not work without HDMV descriptors." I am quite certain that i didn't got those with all the ones that currently works.
I have tried with the latest nightly build. Here i get the Atmos track - but no Dolby Vision. Here i don't get any error message.
Is it possible that the TS-muxer can be corrupted somehow? The files appear unchanged. Properties on the files say they were last changed on Feb 22.
rouhsss
Post
by rouhsss » Tue Jun 28, 2022 10:12 am
One question. What fully plays MKV UHD remux with DV (profile 7) in 2022? Lg c1, nvidia shield etc...?
dwalme
Post
by dwalme » Tue Jun 28, 2022 3:53 pm
evilmatcher wrote: ↑Tue Jun 28, 2022 5:34 am
On the General tab of tsMuxeR select the option "Generate HDMV compatible TS". That will fix your issue.
evilmatcher
Post
by evilmatcher » Tue Jun 28, 2022 6:20 pm
dwalme wrote: ↑Tue Jun 28, 2022 3:53 pm
You're a star. It fixed my struggles. I have no idea on how that has been disabled. I have not done it intentional.
dwalme
Post
by dwalme » Tue Jun 28, 2022 7:05 pm
evilmatcher wrote: ↑Tue Jun 28, 2022 6:20 pm
If you select m2ts or any other option and then select ts as output that option will be unchecked.
I stumbled upon it myself the same way. The warning message was a clue but the inconsistent behavior of the option being selected or not was confusing.
realbabilu
Post
by realbabilu » Tue Jun 28, 2022 8:09 pm
RESET_9999 wrote: ↑Sun Jun 26, 2022 8:24 pm
go read the past weeks in this thread, all the test have been done and confirmed that the appletv only support genuine p5 DV. ( i dont know about other apple devices)
Finally i got one sample working perfectly that coming with Profile 05.06.
I compare DV test remux with Dovi_Script mp4muxer+mp4box and Subler for mac with subtitles.
The Dovi_Script with mp4box last subtitles muxing detect DV but can't detect the Dolby Atmos (only Dolby Audio DD+). The TV will detect Atmos if it use only mp4muxer (no integrated subtitles mux).
The Subler for mac integrated subtitles but my TV can detect the Dolby Atmos and Dolby Vision. It mux faster then mp4muxer.
Just share my experience.
thetoad
Post
by thetoad » Fri Jul 01, 2022 7:54 am
Q, has there been any work done for colorspace conversion for DV profile 5 to HDR10 or SDR? There's plenty of work on tonemapping HDR10 to SDR, but wondering about for DV content on non DV devices.
quietvoid
Post
by quietvoid » Fri Jul 01, 2022 12:44 pm
thetoad wrote: ↑Fri Jul 01, 2022 7:54 am
Of course, it has been supported in libplacebo and mpv for a while now.
Also, Jellyfin has beta support for real time transcoding:
https://www.reddit.com/r/jellyfin/comme ... is_coming/
ArArdin
Post
by ArArdin » Sat Jul 02, 2022 8:39 am
quietvoid wrote: ↑Fri Jul 01, 2022 12:44 pm
Hey, this is new to me. Am I right to assume you mean the cli player
https://github.com/mpv-player/mpv ??
Or is there a GUI player too that can tonemap P5 DV to HDR/SDR?
quietvoid
Post
by quietvoid » Sat Jul 02, 2022 12:57 pm
ArArdin wrote: ↑Sat Jul 02, 2022 8:39 am
Yes, that mpv. It is a GUI player.
You can also try mpv.net:
https://github.com/stax76/mpv.net
For Dolby Vision tone mapping, you need to use vo=gpu-next in the config. Or with the --vo=gpu-next flag in CLI.
ArArdin
Post
by ArArdin » Sat Jul 02, 2022 1:39 pm
Thanks quietvoid. V5.8.0.0-beta working like a charm with DV P5
(I'm on win 7).
[EDIT] Later version mpvnet 6.0.3.0 also working.
JoseTheBae
Post
by JoseTheBae » Tue Jul 05, 2022 12:07 am
Is there some trick to enabling lossless audio in Plex on the Ugoos AM6B Plus? Lossless audio works in Kodi. Oddly, the 32-bit Kodinerds build seems to discard the Full Enhancement Layer in Dolby Vision, even though Plex plays it perfectly. If I can just get lossless audio working in Plex, I will finally achieve full Dolby Vision (FEL) playback.
