Just bought a WH16NS60 - wanting to flash it
CrazyWookiee
It came with 1.03 installed. Looking around, I need to put 1.02 on it. I plan on going with 1.02 MK. Is there a flash tool that works with Win 7 or Linux?
Re: Just bought a WH16NS60 - wanting to flash it
From the topic SDFtool Flasher:
Here is the old original version of the SDFtool flasher: (works on Win7)
sdftool_flasher.zip
sdftool_flasher.zip
CrazyWookiee
Thanks. I downloaded the pack that is mentioned here. I assume 1.03 is the latest MK version. I tried using it and 1.02. The flasher acts like everything worked properly. Nothing seems to have changed in MakeMKV though. It still says 1.03 even when I supposedly flash 1.02.d00zah wrote: Fri Jul 01, 2022 1:05 pm From the topic SDFtool Flasher:
sdftool_flasher.zip
Does MakeMKV report this?
Firmware type: Original (unpatched) or ... (patched) depending on version
Firmware version: 1.0x
If so, you are good to go.
Enc
CrazyWookiee
It does not. Firmware says original. Where you put yes or enabled all say possible with patched firmware.d00zah wrote: Sat Jul 02, 2022 3:47 pm Does MakeMKV report this?
CrazyWookiee wrote: Sat Jul 02, 2022 9:47 pm It does not. Firmware says original. Where you put yes or enabled all say possible with patched firmware.
In SDFTool, check the 'enc?' box before 'Start'.
CrazyWookiee
When I try doing it with "enc?" checked, I get an error saying "command produced error code 0x8f056103."
You should first flash 1.03 MK with "enc". Then - if successful - flash 1.02 in a second step.
CrazyWookiee
I get the error code no matter what I try doing.
you can try my automated flasher its $25 if it works
CrazyWookiee
I finally got it to work. Forgot I left a disc in the drive and that was causing the error for some reason. I'm now on 1.02. I'm now ripping my first UHD disc. Thanks for the help.
I swear people just don't know how to read instructions!! Anyway, glad you got it sorted.CrazyWookiee wrote: Thu Jul 14, 2022 10:22 am I finally got it to work. Forgot I left a disc in the drive and that was causing the error for some reason. I'm now on 1.02. I'm now ripping my first UHD disc. Thanks for the help.
drk9ght1
I just bought the LG WH16NS60 and it had the 1.03 firmware on it also. I successfully flashed to mk 1.02, but need it to be 1.0.
So i tried flashing directly to 1.0 and when flashing it showed everything went through successfully, but makemkv showed it still as 1.02.
I then read that side loading was a successful way in downgrading and proceeded to flash ASUS-BW-16D1HT-3.10-WM01601-211901041014 (successful 100%),
but makemkv still read 1.02. Rebooted and tried flashing with DE_LG_WH16NS60_1.00 (successful 100%) and checked makemkv status and still it read 1.02.
Not sure what I"m doing wrong if anything? If you could please help or point me in the right direction I'd appreciate it?
Once flashed don't check "enc".
