Unable to rip Inception
ericnyc
Post by ericnyc »
Hi everyone. I was unable to rip Inception so I did a full disk backup as I figured might be requested. I will upload the debug log with both attempts (at the bottom).
Re: Unable to rip Inception
Post by mike admin »
005076:0000 Hash check failed for file /BDMV/STREAM/00001.m2ts at offset 803923968, file is corrupt.
005076:0000 Hash check failed for file /BDMV/STREAM/00001.m2ts at offset 804120576, file is corrupt.
It's a bad disc.
ericnyc
Post by ericnyc »
Is it fair to say that whenever you get a hash check, it is a disk with a physical error?
Romansh
Post by Romansh »
ericnyc wrote:Is it fair to say that whenever you get a hash check, it is a disk with a physical error?
Could be dirty; try cleaning it.
Well, it means that the file that was read from the disc is certainly corrupted. Content hash file is like md5sum file for each M2TS file. So yes, hashcheck error is either a bad disc or drive.
