Rider
Posts: 3 Joined: Tue Apr 27, 2021 4:51 pm
Post
by Rider » Tue Apr 27, 2021 11:37 pm
Billycar11 wrote: Tue Apr 27, 2021 10:56 pm
Show us you makemkv drive info
OS-Gerätename: F:
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-UD04
Revision: 1.14
Serienummer: UADL063744WL
Firmware-Datum: 2020-06-15
Highest AACS version: 16
Status: Might be supported in future, keep fingers crossed
Drive platform: Pioneer RS8A10
Firmware version: GENE
Posts: 6390 Joined: Sun Aug 24, 2014 5:49 am
Post
by Billycar11 » Wed Apr 28, 2021 6:43 am
nope no UHD
Rider
Post
by Rider » Wed Apr 28, 2021 7:44 am
Billycar11 wrote: Wed Apr 28, 2021 6:43 am
nope no UHD
also not sometime when?
gutless3690
Posts: 8 Joined: Thu Jun 30, 2022 3:29 am
Post
by gutless3690 » Thu Jun 30, 2022 3:48 am
I have the BDR-209DBK with 1.51 firmware too, and I see it is now in the supported list???? Does this mean I can rip THE BATMAN?!?!! Or am I reading this wrong that says "208 and up should be supported"?
Posts: 4853 Joined: Tue Feb 19, 2019 10:32 pm
Post
by Coopervid » Thu Jun 30, 2022 8:35 pm
Being suppoprted by Libredrive doesn`t mean that your drive can read UHDs. Unless there is some firmware patch in the future your drive can`t read UHDs.
gutless3690
Post
by gutless3690 » Thu Jun 30, 2022 9:19 pm
Doesn't this:
"PIONEER-BD-RW___BDR-209D-1.51-148709AB-8600ID61-20180508
PIONEER-BD-RW___BDR-209D-1.51-664813FF-8601ID61-20180508"
from the supported list on the first page mean it will work with a BDR-209DBK?
Post
by Coopervid » Thu Jun 30, 2022 11:03 pm
Yes. Libredrive but Libredrive doesn't mean UHD support per se. Just how Makemkv operates the drive. Your drive 209 can't read UHDs.
gutless3690
Post
by gutless3690 » Fri Jul 01, 2022 12:14 am
Ah, sorry. I confused the Libre drive support list as capable of ripping UHD disks. Apologies. Thank you for clarifying.
