LibreDrive for Pioneer drives
#256 Post by Billycar11 » Thu Jun 23, 2022 10:11 pm
crazyaoshi wrote: Thu Jun 23, 2022 2:13 pm
Thank you for the reply. I downloaded the SDF flasher and all in one firmware pack, and flashed according to the instructions.
The firmware dump created something called
dump_user_Logitec_LBD_USB_Device_LU12_212106211345_MO3LBTF0732.tar
I tried flashing with BU40N from the firmware pack.
Libredrive was not enabled, and makemkv says almost nothing changed. Except, AACS was latest version 68, after the flash it was version 76.
Am I doing it wrong, using the wrong firmware, or is my drive impervious to flashing?
Use enc to flash
crazyaoshi
#257 Post by crazyaoshi » Sat Jun 25, 2022 1:10 am
Billycar11 wrote: Thu Jun 23, 2022 10:11 pm
Use enc to flash
Thanks so much. That worked. I didn't realize "use enc to flash" was clickable.
gutless3690
#258 Post by gutless3690 » Thu Jun 30, 2022 3:33 am
So I'm a bit confused. I have a BDR-209DBK with 1.51 (latest) firmware. I see it in the supported list, though all other documentation says it will not be able to read UHD disks. If it is in the above list, I can simply put the 4k disk in and it will read/rip it? Only asking because I have seen where others have said it is not a native UHD reading drive so it won't ever work. Just ordered the 4k version of The Batman and hoping to be able to rip it and others.
Thanks for your time!
#259 Post by Billycar11 » Thu Jun 30, 2022 8:05 am
gutless3690 wrote: Thu Jun 30, 2022 3:33 am So I'm a bit confused. I have a BDR-209DBK with 1.51 (latest) firmware. I see it in the supported list, though all other documentation says it will not be able to read UHD disks. If it is in the above list, I can simply put the 4k disk in and it will read/rip it? Only asking because I have seen where others have said it is not a native UHD reading drive so it won't ever work. Just ordered the 4k version of The Batman and hoping to be able to rip it and others.
currently no but there is work being done on converting pioneer non UHD drives to UHD
not sure when it will be released could be days could be years
gutless3690
#260 Post by gutless3690 » Thu Jun 30, 2022 3:01 pm
Doesn't this:
"PIONEER-BD-RW___BDR-209D-1.51-148709AB-8600ID61-20180508
PIONEER-BD-RW___BDR-209D-1.51-664813FF-8601ID61-20180508"
from the supported list on the first page mean it will work with a BDR-209DBK?
#261 Post by Coopervid » Thu Jun 30, 2022 11:05 pm
You need to get a LG drive or a Pioneer that has an "U" in its name.
#262 Post by MartyMcNuts » Thu Jun 30, 2022 11:52 pm
gutless3690 wrote: Thu Jun 30, 2022 3:01 pm Doesn't this:
It means that model is LibreDrive compatible but LibreDrive does not equal UHD compatible.
gutless3690
#263 Post by gutless3690 » Thu Jun 30, 2022 11:52 pm
Ah, sorry. I got super confused looking at the UHD drive page which brought me to this one. I misunderstood the support listed as UHD ripping, not Libre. My mistake. Thank you.
notefix22
#264 Post by notefix22 » Sat Jul 02, 2022 12:00 pm
Please support this drive installed new version firmware.
OS device name: *:
Manufacturer: PIONEER
Product: BD-RW BDR-S12JX
Revision: 1.02
Serial number: ****
Firmware date: 2022-02-10
Compaqcol
#265 Post by Compaqcol » Mon Jul 04, 2022 9:41 am
I ordered the Pioneer BDR-XS07TUHD from Asmcom last week, it came the next day! Super fast delivery and good communication cannot fault him. I would highly recommend and the drive works great!
Letsplaybar
#266 Post by Letsplaybar » Wed Jul 13, 2022 9:11 pm
can anyone tell me if I still have to do something on my device and if so where I can find the appropriate firmware?
Here my Data:
Laufwerksinformation
OS-Gerätename: G:
Produzent: ASUS
Produkt: BW-12D1S-U
Revision: E411
Serienummer: ***
Firmware-Datum: 2017-12-21
Highest AACS version: 76
Drive platform: Pioneer RS8601
Firmware version: ID44
FrankInUtah
#267 Post by FrankInUtah » Thu Jul 14, 2022 5:52 am
Please add:
OS device name: W:
Product: BD-RW BDR-212U
Revision: 1.00
Serial number: **(I have two)**
Firmware date: 2019-01-10
Drive platform: Pioneer RS8F01
Firmware version: ID58
Thank you for all your hard work!
My flashed Asus BW-16D1HT are doing great, and now my Pioneer BDR-209M say Libre is enabled. I've gotta try that :-)
avandy
#268 Post by avandy » Thu Jul 14, 2022 11:21 am
I got my first 4k Blu rays yesterday and put it into my Pioneer drive and the disc wasn't recognized, MakeMKV said there was no disc inserted. From what I read on the supported LibreDrive list, my drive and firmware is supported. Any advice? Or rather, what am I missing?
Discs were:
Jaws 45th Anniversary Limited Edition
Indiana Jones and the Raiders of the Lost Ark
OS device name: E:
Product: BD-RW BDR-XD05
Revision: 3.01
Serial number: ------------
Firmware date: 2014-12-26
Highest AACS version: 68
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.01/ID34
#269 Post by Billycar11 » Thu Jul 14, 2022 11:36 am
avandy wrote: Thu Jul 14, 2022 11:21 am I got my first 4k Blu rays yesterday and put it into my Pioneer drive and the disc wasn't recognized, MakeMKV said there was no disc inserted. From what I read on the supported LibreDrive list, my drive and firmware is supported. Any advice? Or rather, what am I missing?
Discs were:
OS device name: E:
Revision: 3.01
thats not a uhd pioneer drive see the guide
it may be possible in the future to flash it but not yet
avandy
#270 Post by avandy » Thu Jul 14, 2022 11:47 am
Yup, that's what I was missing!
Thanks. I've had this drive for a while, I just figured the Model number would be different between a plain Bluray drive and one capable of 4k. I kept reading the Pioneer BDR-XD05 can read 4k Blurays, so I thought I'd give it a shot.
