Movies
Predator66666
Movies
Post by Predator66666 » Tue Jun 28, 2022 9:03 am
Hi!
With some films like z.Bsp. Jupiter Ascending, Nobody etc.,
I have the problem that after ripping the film runs smoothly,
but the sound is totally choppy. What can that be?
If you want, I can create a short sequence for you with my screen recorder.
Re: Movies
Post by dcoke22 » Wed Jun 29, 2022 2:04 am
Predator66666 wrote: Tue Jun 28, 2022 9:03 am With some films like z.Bsp. Jupiter Ascending, Nobody etc.,
I'm curious what film is z.Bsp.?
Almost always playback problems like you describe are a limitation of whatever your playback system is. Try a different player and see if it helps.
