dwalme
#6766 Post by dwalme » Tue Jun 28, 2022 3:53 pm
evilmatcher wrote: Tue Jun 28, 2022 5:34 am
dwalme wrote: Sun Jun 26, 2022 4:36 pm I just recently did the same thing and I tested my copy with my X800M2 after I read this. I have a silent core and have no issues with TrueHD/Atmos playing properly.
I have tried with the copies I made last week of Back to the Future 1 + 2 with the same TS-muxer version from the DOVI-scripts (Feb 22) as i did last week. When i make a new TS-version of those backups it also fails - no sound on the x800m2. When I play all the ones currently on my NAS on the x800m2, all of them works. When using the Feb 22 TS-muxer version i now get an error message stating "Warning: PGS might not work without HDMV descriptors." I am quite certain that i didn't got those with all the ones that currently works.
I have tried with the latest nightly build. Here i get the Atmos track - but no Dolby Vision. Here i don't get any error message.
Is it possible that the TS-muxer can be corrupted somehow? The files appear unchanged. Properties on the files say they were last changed on Feb 22.
On the General tab of tsMuxeR select the option "Generate HDMV compatible TS". That will fix your issue.
evilmatcher
#6767 Post by evilmatcher » Tue Jun 28, 2022 6:20 pm
dwalme wrote: Tue Jun 28, 2022 3:53 pm On the General tab of tsMuxeR select the option "Generate HDMV compatible TS". That will fix your issue.
You're a star. It fixed my struggles. I have no idea on how that has been disabled. I have not done it intentional.
dwalme
#6768 Post by dwalme » Tue Jun 28, 2022 7:05 pm
evilmatcher wrote: Tue Jun 28, 2022 6:20 pm
If you select m2ts or any other option and then select ts as output that option will be unchecked.
I stumbled upon it myself the same way. The warning message was a clue but the inconsistent behavior of the option being selected or not was confusing.
realbabilu
#6769 Post by realbabilu » Tue Jun 28, 2022 8:09 pm
RESET_9999 wrote: Sun Jun 26, 2022 8:24 pm go read the past weeks in this thread, all the test have been done and confirmed that the appletv only support genuine p5 DV. ( i dont know about other apple devices)
Finally i got one sample working perfectly that coming with Profile 05.06.
I compare DV test remux with Dovi_Script mp4muxer+mp4box and Subler for mac with subtitles.
The Dovi_Script with mp4box last subtitles muxing detect DV but can't detect the Dolby Atmos (only Dolby Audio DD+). The TV will detect Atmos if it use only mp4muxer (no integrated subtitles mux).
The Subler for mac integrated subtitles but my TV can detect the Dolby Atmos and Dolby Vision. It mux faster then mp4muxer.
Just share my experience.
thetoad
#6770 Post by thetoad » Fri Jul 01, 2022 7:54 am
Q, has there been any work done for colorspace conversion for DV profile 5 to HDR10 or SDR? There's plenty of work on tonemapping HDR10 to SDR, but wondering about for DV content on non DV devices.
quietvoid
#6771 Post by quietvoid » Fri Jul 01, 2022 12:44 pm
thetoad wrote: Fri Jul 01, 2022 7:54 am Q, has there been any work done for colorspace conversion for DV profile 5 to HDR10 or SDR? There's plenty of work on tonemapping HDR10 to SDR, but wondering about for DV content on non DV devices.
Of course, it has been supported in libplacebo and mpv for a while now.
Also, Jellyfin has beta support for real time transcoding: https://www.reddit.com/r/jellyfin/comme ... is_coming/
ArArdin
#6772 Post by ArArdin » Sat Jul 02, 2022 8:39 am
quietvoid wrote: Fri Jul 01, 2022 12:44 pm
Hey, this is new to me. Am I right to assume you mean the cli player https://github.com/mpv-player/mpv ??
Or is there a GUI player too that can tonemap P5 DV to HDR/SDR?
quietvoid
#6773 Post by quietvoid » Sat Jul 02, 2022 12:57 pm
ArArdin wrote: Sat Jul 02, 2022 8:39 amHey, this is new to me. Am I right to assume you mean the cli player https://github.com/mpv-player/mpv ??
Yes, that mpv. It is a GUI player.
You can also try mpv.net: https://github.com/stax76/mpv.net
For Dolby Vision tone mapping, you need to use vo=gpu-next in the config. Or with the --vo=gpu-next flag in CLI.
ArArdin
#6774 Post by ArArdin » Sat Jul 02, 2022 1:39 pm
Thanks quietvoid. V5.8.0.0-beta working like a charm with DV P5 :D (I'm on win 7).
[EDIT] Later version mpvnet 6.0.3.0 also working.
JoseTheBae
#6775 Post by JoseTheBae » Tue Jul 05, 2022 12:07 am
Is there some trick to enabling lossless audio in Plex on the Ugoos AM6B Plus? Lossless audio works in Kodi. Oddly, the 32-bit Kodinerds build seems to discard the Full Enhancement Layer in Dolby Vision, even though Plex plays it perfectly. If I can just get lossless audio working in Plex, I will finally achieve full Dolby Vision (FEL) playback.
JoseTheBae
#6776 Post by JoseTheBae » Tue Jul 05, 2022 2:32 pm
ragico wrote: Fri Feb 26, 2021 12:45 am With Ugoos AM6 plus/Kodi Matrix DV edition (thanks @Fandangos and @quietvoid) Saving Private Ryan (MKV DV) no flicKering like the m2ts on Sony X700.
This is the first time that a device (except Sony X700) does not flickers on this film.
I tried Firestick 4K, Shield 2019 and Google Chromecast with Google TV.
In Ugoos (latest firmware 0.40) also HD audio (True HD Atmos and DTS X) works in passtrough in Kodi.
My soundbar confirms.
Can you please share a link to that specific Kodi build that did not produce flickering for the opening of Saving Private Ryan? For some reason, I get flickering on my Ugoos AM6B Plus in Kodinerds, but not in Plex.
JoseTheBae
#6777 Post by JoseTheBae » Tue Jul 05, 2022 2:44 pm
NiCE77 wrote: Thu Feb 18, 2021 5:46 pm I've tested the Ugoos AM6 Plus media player (Amlogic S922X-J), and it seems, the internal player correctly processing the Full Enhancement Layer from DTDL mp4 file!
https://youtu.be/RYeLEYk_Bys
I'm tried with Kodi 19 custom build and working same with the P7 STDL mkv too!
Can you please share a link to this custom Kodi build? Kodinerds discards the Full Enhancement Layer on my Ugoos AM6B Plus, but Plex does not.
JoseTheBae
#6778 Post by JoseTheBae » Tue Jul 05, 2022 3:46 pm
RESET_9999 wrote: Sat Mar 27, 2021 12:07 am I got PLEX to trigger both DV and Atmos in a MKV container and for the 5 minutes I watched (power rangers), it was perfectly stable. AVR showed lossless Atmos.
but once again when I stopped playback and started it again, back to lpcm stereo and no more DV. Just gotta wait for a ugoos update, I just sent them another email.
What Plex Client version was this on? I can't get Plex to output lossless audio on my Ugoos AM6B Plus.
#6779 Post by RESET_9999 » Tue Jul 05, 2022 6:43 pm
JoseTheBae wrote: Tue Jul 05, 2022 3:46 pm What Plex Client version was this on? I can't get Plex to output lossless audio on my Ugoos AM6B Plus.
no particular version. I was able to make it work about 3-4 times and it just seem to work randomly.
JoseTheBae
#6780 Post by JoseTheBae » Tue Jul 05, 2022 7:49 pm
I downloaded the modified ExoPlayer build, which I made Kodi's default player. Unfortunately, playback stutters a lot, although it does appear to be processing the Full Enhancement Layer. Is there some other player with smoother Dolby Vision playback, or perhaps a newer version of ExoPlayer?
