failed to open disc
gorbold
failed to open disc
Blu-ray discs of the movies "Belfast" and "Licorice Pizza" would not copy and ended with a "failed to open disc" error message. Both showed similar behavior where all files are skipped when attempting to open. I'm running MacOS and saw the same failure on two computers. log attached
Re: failed to open disc
MakeMKV v1.16.7 darwin(x64-release) started
Optical drive "DVD+R-DL HL-DT-ST DVDRW GA32N KC08 K0ZA4R80845d" opened in OS access mode.
Optical drive "BD-RE HL-DT-ST BD-RE BP50NB40 1.03 SIM2121C62653d" opened in OS access mode.
Downloading latest SDF to /Users/user/.MakeMKV ...
Using Java runtime from /Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/bin/java
Title #00156.mpls has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00157.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01104.mpls has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01105.mpls has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01106.mpls has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01107.mpls has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01108.mpls has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01387.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01389.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01390.mpls was skipped
Title #01391.mpls was skipped
Title #01392.mpls has length of 58 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01393.mpls was skipped
Title #00800.mpls was skipped
Title #00149.mpls was skipped
Title #01103.mpls has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.mpls has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00601.mpls has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00174.m2ts has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00175.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00179.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00180.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00181.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00182.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00183.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00184.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00185.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00165.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00173.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00178.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00246.m2ts was skipped
Title #00247.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00448.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00449.m2ts was skipped
Title #00450.m2ts was skipped
Title #00451.m2ts has length of 58 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00452.m2ts was skipped
Failed to open discJava version history
gorbold
My system seems to have the latest version of Java per the update app on my computer in terminal. I get the information below from the console. The number of files attempting to open does not seem unusual. I have not seen this error message before and yeah it seems like makemkv just halts when the error message is posted even though the system is seeing the disc and reporting the movie title correctly, etc - like the disc is open.
From console:
java version "1.8.0_333"
Java(TM) SE Runtime Environment (build 1.8.0_333-b02)
Java HotSpot(TM) 64-Bit Server VM (build 25.333-b02, mixed mode)
From console:
The log says:
In MakeMKV's preferences, on the Protection tab, what is listed for the Custom Java executable location?
Mine, as you can see, is empty. I think that means it using the system default.
Using Java runtime from /Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/bin/javaMine, as you can see, is empty. I think that means it using the system default.
gorbold
The version of Java does not matter. I deleted Java on my stystem and re-loaded the latest. It still fails in the same manner. log with debug turned on.
Debug logging enabled, log will be saved as /Users/geoffgorbold/MakeMKV_log.txt
Downloading latest HK to /Users/geoffgorbold/Library/MakeMKV ...
DEBUG: Code 0 at "\_KTw9N7~>xh;%/:121266143
Using Java runtime from /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java
DEBUG: Code 0 at G]Q"HrHKY1 'Yz^!aH:213130007
DEBUG: Code 1 at E>AGfY%!Ukem2|PRG:213131548
Title #01109.mpls has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01111.mpls has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00100.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00600.mpls has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01056.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00152.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00036.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00037.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00038.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00039.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00040.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00041.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00042.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00043.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00044.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00045.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00046.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 0 at -|5`i-;F,W5c;8<~:29404671
DEBUG: Code 0 at Ma^k}kvHb\`C?DEBo:121263613
DEBUG: Code 0 at V\Vb/q~=RUa}@6 O:29406005
DEBUG: Code 0 at V\Vb/q~=RUa}@6 O:29397978
DEBUG: Code 0 at ,x1~_`sN@H5 #}2NxTys:29398461
DEBUG: Code 0 at (iP"cY!Jwryc<h3[2:121265177
DEBUG: Code 0 at (iP"cY!Jwryc<h3[2:29399979
DEBUG: Code 0 at W~um;-X-yi^32.E<:121262578
DEBUG: Code 0 at "_4BXIZ62@tu@u*:29402256
DEBUG: Code 0 at -|5`i-;F,W5c;8<~:213117058
Title #00010.mpls was skipped
Title #00047.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00052.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00049.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00063.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00053.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00050.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00054.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00055.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00056.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00057.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00058.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00059.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00048.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00060.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00064.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00065.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00066.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00067.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00068.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00069.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00070.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00072.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00073.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00071.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00074.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00075.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00076.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00077.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00078.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00079.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00080.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00083.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00084.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00085.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00086.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00612.mpls was skipped
Title #01112.mpls has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01113.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01115.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01218.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01219.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01220.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01388.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01350.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01351.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01352.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01353.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01354.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01355.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01356.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01357.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01358.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01359.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01360.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01361.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01362.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01363.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01364.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01365.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01366.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01367.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01368.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01369.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01370.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01371.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01372.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01373.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01374.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01375.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01376.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01377.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01378.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01379.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01380.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01381.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01382.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01383.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01384.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01385.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01386.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Failed to open disc-
Using Java runtime from /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/javaOver in the Linux section, they've run into some Java problems and are working about it by setting the custom executable location to
/bin/trueI wonder what happens if you give that a try?
gorbold
It makes sense that the path has changed as I went through the recommended process of uninstalling all older versions of java and reinstalling the latest version. This prevented MakeMKV from using an old version. The path for java is a default for installation. I don't see how a directory path could affect the outcome. I have seen BD copies work successfully in MakeMKV without java being used at all. I don't think it is the problem here as the changes I've made do not affect the outcome. I'd like to know what the debug info tells us about the failure and solve the problem based on that.
Ah, I misunderstood. I thought you tried to remove Java from your system. I didn't realize you reinstalled it. Hence my confusion from seeing the log info about MakeMKV using Java.
You're correct, you don't don't need Java for MakeMKV to work.
I still speculate that Java might be silently crashing. The post I linked to is the Linux crowd effectively telling MakeMKV that they don't have Java on their system so it doesn't use it (and thus doesn't crash).
However if you want to figure out what the debug messages mean, that's fair enough. I can not help you with that, however. The program's author, who has access to the source code, would have to comment. It has been my observation that he generally doesn't comment on things like this.
gorbold
I changed the path, Java didn't load, and I got the exact same error messages. I assume I'd have to reinstall java in a custom directory for Java to load with a custom path. But when I get the same error messages with or without Java, it makes sense that the problem lies in makemkv code. Agree?
kspenser
I can successfully open and begin to copy Licorice Pizza but it's failing after near completion...it's a continuous I/O and then "Illegal Request" error...each repeating 5 times then 6 times..like:
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk4' at offset '24879955968'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00246.m2ts' at offset '24879955968'
Just updated to the latest version of MKV and the disc is brand new. I re-copied some other BD's I have too just make sure my drive was in tact and wasn't any other hardware related issue(s). Sorry if this doesn't help just wanted to report this title is also having issues for me.
Bokonon42
Hi, did anyone every find success with 'Licorice Pizza' Blu ray? I have not had any issues with anything until this disc. It actually ripped a 6GB file for me but it was 720p... thanks.
According to web searches, "Licorice Pizza" is typically sold as a BD-DVD set, and the DVD would weigh in at about 6GB... Are you sure you ripped the bluray?
