On the fly decription don't working
panospav
#1 Post by panospav » Fri Jun 17, 2022 12:29 pm
I am using Makemkv with MPC HC on the fly decryption.
Everything were fine up to the time I changed the connection of my second monitor:
it was connected to the AVR and I connected it straight to graphics card display port.
After that I cannot use on the fly decryption with MPC HC.
Java 32 and 64 bits are installed.
I even clean installed windows, but the problem persists.
I even installed VLC but it is also not working.
Any help would be much appreciated.
Screenshot 2022-06-17 144655.png (336.91 KiB) Viewed 20624 times
Screenshot 2022-06-17 144752.png (108.52 KiB) Viewed 20624 times
Screenshot 2022-06-17 144717.png (294.13 KiB) Viewed 20624 times
Re: On the fly decription don't working
#2 Post by Billycar11 » Fri Jun 17, 2022 12:58 pm
panospav wrote: Fri Jun 17, 2022 12:29 pm Hi,
Do you own makemkv or are you using the beta key or free trial?
panospav
#3 Post by panospav » Fri Jun 17, 2022 2:19 pm
Yes , I have purchased a registration key ,last Saturday.
panospav
#4 Post by panospav » Fri Jun 17, 2022 7:35 pm
I just install Any Dvd trial version and it is decrypting the discs , what is the problem of Makemkv ?
#5 Post by Billycar11 » Fri Jun 17, 2022 10:39 pm
panospav wrote: Fri Jun 17, 2022 2:19 pm Yes , I have purchased a registration key ,last Saturday.
Make sure you are using the key on your new install and check and uncheck the intagration after making sure your key is in.
Make sure to hit ok in-between checking and unchecking
panospav
#6 Post by panospav » Wed Jun 22, 2022 8:14 am
After a week trying to recover makemkv integration with MP HC, there is no positive result.
I don't care if everyone could use the registration key as it seems to me that it is not valid though I have paid for it.
As you can see in attachments, integration is ticked and makemkv indicates that registration is on.
Screenshot 2022-06-22 110530.png (247.99 KiB) Viewed 20535 times
Screenshot 2022-06-22 105556.png (169.87 KiB) Viewed 20535 times
#7 Post by Billycar11 » Wed Jun 22, 2022 8:53 am
panospav wrote: Wed Jun 22, 2022 8:14 am After a week trying to recover makemkv integration with MP HC, there is no positive result.
pc specs?
it does show the chapters maybe your system does not support h.265
panospav
#8 Post by panospav » Wed Jun 22, 2022 11:29 am
Asus b550f
Ryzen 7 3800x
GSkill Ripjaws 2x8GB 3200MHz DDR4
RTX 3080 MSI GAMING TRIO Z
Corsair RM1000x 80 plus Gold
This particular disc is Mission Impossible 1, a simple Blu-ray disc.
Using trial version of Anydvd I watched several UHD Blu-ray discs.
I believe that somehow the registration number is not valid.
Using MakeMkv the first five days, I watched UHD Blu-ray discs using MPC HC integration.
This is a simple Blu-ray disc and my system can handle HEVC decoder or any other decoder.
#9 Post by Billycar11 » Wed Jun 22, 2022 12:01 pm
panospav wrote: Wed Jun 22, 2022 11:29 am Asus b550f
Ryzen 7 3800x
Yeah everything there is good hmm strange.
I have seen other problems like this before if there are multiple decryptors in the mpc or vlc folder.
You could try uninstalling both VLC and mpc then reinstall and see if it works that should delete the directorys and any other decoders in there then only add makemkvs decoder
panospav
#10 Post by panospav » Wed Jun 22, 2022 12:15 pm
Is there a chance that VLC cannot work simultaneously with MPC HC ?
#11 Post by Billycar11 » Wed Jun 22, 2022 12:20 pm
panospav wrote: Wed Jun 22, 2022 12:15 pm Is there a chance that VLC cannot work simultaneously with MPC HC ?
No I don't that should be an issue
panospav
#12 Post by panospav » Wed Jun 22, 2022 6:52 pm
I followed the advice uninstalling all video players ,reinstalling MPC HC but ,though, it opened the disc within seconds ,still black screen.
Is there, any other particular MakeMkv setting , for the integration ? I run MakeMkv as administrator,in Preferences Enable intenet acesss ,Expert mode and AV synchronization messages are ticked ,Language and preffered language are English and in Integration MPC HC is ticked.
panospav
#13 Post by panospav » Wed Jun 22, 2022 7:33 pm
I noticed that when MakeMkv worked properly, was using Java to open the disc.Now it doesn't.
Which could be the reason ?
#14 Post by Billycar11 » Wed Jun 22, 2022 9:46 pm
panospav wrote: Wed Jun 22, 2022 7:33 pm I noticed that when MakeMkv worked properly, was using Java to open the disc.Now it doesn't.
Not sure sorry I thought the uninstall would fix it
panospav
#15 Post by panospav » Thu Jun 23, 2022 8:00 am
I replaced my psu last saturday.Could this be the reason to create conflicts in Windows ?
