Apologies if this has been asked, but lately, it seems like any new UHD discs I try to rip make a noise like they're trying to read and fail to mount. Never had issues with blu-ray or dvd. Could be coincidence but seems to happen with newer UHD discs (No Time to Die, Matrix Resurrections)
I have a flashed WH16NS60
Any ideas are appreciated!
Issues with newer UHD discs not mounting
ryanbutterworth
Re: Issues with newer UHD discs not mounting
Ryan, I have removed the two attached files you posted, because they're not relevant to the problem.
Is the drive doing this for ALL UHD disks, or just the two you mentioned? It sounds like the drive is not UHD-capable, which would explain the inability to load UHD disks. What is the drive, actually? Not what you flashed it to, but the drive itself?
I have ripped both No Time to Die (2021) and The Matrix Resurrections (2021) so they're not inherently unripable.
ictbydesign
Ripped both of these as well using the same drive you mention - WH16NS60.
