LG WH14NS60 1.05 not giving an error, but also not updating the firmware - MacOS Terminal method
Zorat
Post by Zorat » Wed Jun 22, 2022 1:27 am
NOTE: UPDATED WITH FIX from below to help others.
Hey all,
I have tried to not post this, and gone through the guide a number of times, please tell me which part I am making a mistake with.
I have an LG WH14NS40 1.05 firmware.
From my understanding I need to flash this to the 1.05mk firmware first, and then flash it to the WH16NS60 1.02 after.
As told, I downloaded:
1. sdf.bin
2. the MK firmware Pack 20200720
3. The All You Need Firmware Pack
I then put these 3 files in the /tmp directory
sdf.bin
HL-DT-ST-BD-RE_WH14NS40-NS50-1.05-NM00900-212005061444.bin
HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
I then went and ran the steps as described.
First identify the drive that I am trying to update (1E1948EC)
MacOS % ./makemkvcon f -l
Found 2 drives(s)
00: /IOBDServices/B7CA7A1A
HL-DT-ST_BD-RE__WH16NS60_1.02_211810291936_SIK96H4BA552
01: /IOBDServices/1E1948EC
HL-DT-ST_BD-RE__WH14NS40_1.05_212005061444_M42M3HE1747
Flash the MK firmware to that drive (No Errors) NOTE THIS WAS UPDATED, Have to use ENC not MAIN for this
MacOS % ./makemkvcon f -d '/IOBDServices/1E1948EC' -f /tmp/sdf.bin rawflash enc -i /tmp/HL-DT-ST-BD-RE_WH14NS40-NS50-1.05-NM00900-212005061444.bin
Reading input file /tmp/HL-DT-ST-BD-RE_WH14NS40-NS50-1.05-NM00900-212005061444.bin
Current Drive ID: HL-DT-ST_BD-RE__WH14NS40_1.05_212005061444_M42M3HE1747
yes
100% Operation finished
Done successfully
Flash the WH16NS60 1.02 driver USING MAIN instead of ENC Here
MacOS % ./makemkvcon f -d '/IOBDServices/1E1948EC' -f /tmp/sdf.bin rawflash main -i /tmp/HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Reading input file /tmp/HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
yes
Done successfully
I then ran this to confirm what firmware the drive had
Found 2 drives(s)
MacOS %
And it didn't take, but didn't give me any errors.
I am a paid MakeMKV member and love the service, and appreciate anyones time to help me determine what I am doing incorrectly.
Re: LG WH14NS60 1.05 not giving an error, but also not updating the firmware - MacOS Terminal method
Post by Billycar11 » Wed Jun 22, 2022 1:31 am
enc as the guide says instead of main
Zorat
Post by Zorat » Wed Jun 22, 2022 1:52 am
Thanks. I will fix the above so that others that have the same issue can see the correct context. I missed that one step of enc for the first one, and then leaving it main for the 2nd flash.
