DE = an original firmware with the downgrade bit enabled
MK = modified firmware to re-enable the functions needed for LibreDrive
Ok for software like DEUHD and other dvdfab is better 3.10 MK or 3.01 DE?SamuriHL wrote: Sat Feb 12, 2022 5:08 pm DE = an original firmware with the downgrade bit enabled
The 3.02 is better for critical discs if read errors occur, 3.10 is faster for uncritical read-outs.
Can't speak to DeUHD as I don't use it but DVDFab will work on 3.02. I THINK it also works on 3.10MK but it's been a while since I've used that drive and don't currently have a working machine to test it on without ripping apart a USB case. Strictly speaking, DVDFab tends to favor original firmware.Koubafire wrote: Sat Feb 12, 2022 5:46 pm Ok for software like DEUHD and other dvdfab is better 3.10 MK or 3.01 DE?
michaelsft
HI, I have the ASUS BW-16D1HT and in the past I flash the following firmware to it: ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin
I am trying to sell it but if I can't find a buyer who wants a flashed drive I'd have to sell it as stock again. Is it possible to flash it back using the new SDFTool and could someone be kind enough to point me to the correct firmware that I would need?
Sorry to be a pain, I have been looking on here but there is a lot of information to go through and it's a little confusing to me.
LibreDrive Information in MakeMKV
Firmware version: 3.10
No need to sell it as stock that's silly the firmware does not effect any of the features so you can just leave itmichaelsft wrote: Mon Jun 20, 2022 3:43 pm HI, I have the ASUS BW-16D1HT and in the past I flash the following firmware to it: ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin
michaelsft
Sure but the sleep bug issue definitely does affect it if you don't know why it happens.
yeah but the sleep bug only happens on UHD discs and if your using this as a stock drive it would never even see UHD discsmichaelsft wrote: Tue Jun 21, 2022 10:00 am Sure but the sleep bug issue definitely does affect it if you don't know why it happens.
so again its only benefits
JediFonger
thank you for this tool, i bought this drive a while ago and finally had a 4k UHD disc i wanted to rip/backup and downloaded the Asus Flasher .exe & loaded the mk 3.10 firmware and it was done in a jiffy! fantastic!
ASUS BW-16D1HT
thank you!
strangely enough i used the SDFtool Flasher 1.3.4 GUI and did the same but that one didn't work, even though i restarted the computer. weird.
ASUS BW-16D1HT
thank you!
metaleggman
I actually had used multiple UHD discs, but just mentioned one. I just now re-flashed it using the new flasher and it worked! Huzzah! Don't know why it didn't work before, but I tried ripping The Big Lebowski, didn't work, reflashed, used recovery, boom, it worked. Don't know if something changed between then and now, or if I just did it wrong before, but either way, love all of y'all helping us.MartyMcNuts wrote: Wed Nov 10, 2021 9:38 pmThe BP50NB40 and WP50NB40 MK firmware unlocks LibreDrive but the firmware still does not allow UHD ripping. This is why the BP60NB10 1.00-MK firmware is used. I really don't see how the firmware "didn't work." It either flashed successfully or it didn't. Your issue is hard to diagnose as you really need to try multiple UHD discs first. No one drive will read every UHD disc. Some drives just don't like certain discs and refuse to read them, thus the reason why a large portion of people have 2+ drives. It could also be a case of your UHD disc being bad. Try cleaning the disc before trying to read it again and see how that goes.metaleggman wrote: Wed Nov 10, 2021 11:55 amYes haha, I did read the thread, but I was playing around and tried the HBD firmware because the BP60NB10 firmware didn't work. I just recovered to get back to the WP50NB40 1.03-MK firmware, but even then, when flashing to the BP60NB10 1.00-MK firmware, it still can't read my UHD discs in MakeMKVMartyMcNuts wrote: Sat Nov 06, 2021 10:15 pm
If you have used the SDFtool Flasher, did you read the thread?? The HBD firmware were made obsolete once the SDFtool Flasher became available. I have flashed plenty of WP50NB40 drives for UHD ripping. It is exactly the same process as the BP50NB40.
1. Flash drive to WP50NB40 1.03-MK.
2. Flash the drive to BP60NB10 1.00-MK
3. Enjoy ripping UHD discs.
Since you have already flashed the drive to the HBD firmware, I suggest trying step 2 above. If it won't flash, use the recovery option to get back to WP50NB40 1.03-MK firmware, then start again from step 1.Before I flashed anything, I made sure to dump the oem firmware it came with. Should I attempt to recover to or flash that firmware and perhaps attempt to start over clean? Regular BDMVs are read just fine by MakeMKV. Is it possible my drive is compatible with the WP50NB40-NB50 1.03-MK firmware to unlock LibreDrive, but not able to read UHD movies? Is there any way to tell the drive has been flashed correctly, like a change in the Drive Information in MakeMKV? When I originally flashed 1.03-MK, it showed that LibreDrive had been fully enabled, but when flashing any other firmware after that, everything seems to stay the same.
To be clear, after flashing to the BP60NB10 1.00-MK firmware, and upon inserting a UHD disc (in this case Once Upon a Time in Hollywood), the drive will make some seeking noises for about two minutes, and then MakeMKV will say there's no disc in the drive.
The SDFtool Flasher seems fairly well made and easy to use, hence why I'm wondering if my drive seemingly can't be made to read UHD discs, mine specifically I suppose. Especially since your instructions in the threads are fairly straightforward.
jsmith1299
Hi All,
I have a BW-12b1st manufactured in May 2013 with version 1.00. When I try to burn anything using Nero it just spits the disc out and errors. Is there any firmware I can cross flash this with? I had this drive lying around and never used it until today.
Nope.jsmith1299 wrote: Fri Jan 13, 2023 7:30 pm Hi All,
When trying to do this:
Asus BW-16D1HT on any Firmware directly to > Asus BW-16D1HT 3.10MK I get an Update Failure 4. The hard drive activity light comes on SOLID. Trying again gives "error code 1117, cannot issue command through SPT1".
Drive currently has 3.02 FW.
I flashed my ASUS BW-16D1HT and now my PC won't boot when it's plugged in. Have I bricked my drive?
Trying to downgrade my BW-16D1H-U PRO E116 to A203 or A204, but getting "Updating failure #1"
Any ideas why this is happening?
