dwalme
#6721 Post by dwalme » Thu Jun 16, 2022 4:17 am
RESET_9999 wrote: Thu Jun 16, 2022 3:18 am
dwalme wrote: Thu Jun 16, 2022 1:23 am I found an error in the script.
Running MODE.H->MODE.1->Workflow.1
This generates a P8 file from an HDR10 movie using MadVR.
try 1.3.8
Progress but still errors.
                                      * DoVi_Scripts @RESET_9999 *
 *The output folder by default is the "Dolby-Vision-Tools" Folder, you can change it by editing this bat file
 *Do not move the bat file out of the "Dolby-Vision-Tools" Folder. Make a shortcut instead.
 *Select a mode, a workflow. Drag and drop an input file and wait...
                                           * CHOOSE A MODE *
Main Menu
1) MODE.XP= XML & RPU injector
2) MODE.P5= Profile 5 input to Profile 8 HYBRID MAKER
3) MODE.P7= Profile 7 input (BD/MKV/Convert/Mux/Demux/Inject)
4) MODE.H=  HDR10(madVR) and HDR10plus to DoVi maker
5) MODE.B=  Batch muxer: MKV to TS (DV/DD+/SUB)
6) MODE.M=  MIXED: Remover/Audio/Playlist/MPV/Measurer/HDR10plus_injector and more...
7) MODE.F=  RPU Fixer/Editor/Reader/Extractor/Sync-Inspect/
8) MODE.M4= MP4_muxer(P5/P7/P8)
9) Exit
Choice? [1,2,3,4,5,6,7,8,9]?4
                                           * CHOOSE A MODE *
ECHO is off.
1) MODE.1= HDR10(madVR) or HDR10plus to DoVi maker
2) MODE.2= Batch convert up to 13 HDR10plus videos to DoVi
3) MODE.3= Inject DV from existing measurement file
4) MODE.4= Batch measure a folder with mkv HDR10 files (credit to manni)
5) MODE.5= Back to main menu
Choice? [1,2,3,4,5]?1
                                         * CHOOSE A WORKFLOW *
1) Workflow.1= Convert 1 video + AUTO L5
2) Workflow.2= Convert 1 video + MANUAL L5
3) Workflow.3= Convert 1 video + MANUAL L5 + TrueHD_to_TrueHD.ac3 + DDP_1536kbps
4) Workflow.4= Convert 1 video + MANUAL L5 + TrueHD_to_TrueHD.ac3
5) Workflow.5= Convert 1 video + MANUAL L5 + DDP_1536kbps
6) Workflow.6= Convert 1 video + AUTO L5 + REMOVE HDR10plus (fire stick TV)
7) Workflow.7= Back to main menu
Choice? [1,2,3,4,5,6,7]?1
--This workflow will convert an HDR10 or HDR10plus video to DoVi and set L5 automatically
--The black bars detection may not be perfectly accurate. It's maybe better to measure them manually
Drag and drop your HDR10 or HDR10plus MKV/MP4/TS file and press enter...C:\D\Dolby-Vision-Tools\afgm-00001.ts
Do you want to crop RPU... y or n ? (y when HDR10-BL is cropped) and/or press enter...n
ffmpeg version 5.0.1-full_build-www.gyan.dev Copyright (c) 2000-2022 the FFmpeg developers
  built with gcc 11.2.0 (Rev7, Built by MSYS2 project)
  configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-bzlib --enable-lzma --enable-libsnappy --enable-zlib --enable-librist --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sdl2 --enable-libdav1d --enable-libdavs2 --enable-libuavs3d --enable-libzvbi --enable-librav1e --enable-libsvtav1 --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs2 --enable-libxvid --enable-libaom --enable-libopenjpeg --enable-libvpx --enable-mediafoundation --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-liblensfun --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-ffnvcodec --enable-nvdec --enable-nvenc --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-libshaderc --enable-vulkan --enable-libplacebo --enable-opencl --enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libilbc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint
  libavutil      57. 17.100 / 57. 17.100
  libavcodec     59. 18.100 / 59. 18.100
  libavformat    59. 16.100 / 59. 16.100
  libavdevice    59.  4.100 / 59.  4.100
  libavfilter     8. 24.100 /  8. 24.100
  libswscale      6.  4.100 /  6.  4.100
  libswresample   4.  3.100 /  4.  3.100
  libpostproc    56.  3.100 / 56.  3.100
[mpegts @ 0000023bec450540] start time for stream 3 is not set in estimate_timings_from_pts
[mpegts @ 0000023bec450540] start time for stream 4 is not set in estimate_timings_from_pts
[mpegts @ 0000023bec450540] start time for stream 5 is not set in estimate_timings_from_pts
[mpegts @ 0000023bec450540] start time for stream 6 is not set in estimate_timings_from_pts
[mpegts @ 0000023bec450540] start time for stream 7 is not set in estimate_timings_from_pts
[mpegts @ 0000023bec450540] Could not find codec parameters for stream 3 (Subtitle: hdmv_pgs_subtitle (pgssub) ([144][0][0][0] / 0x0090)): unspecified size
Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options
[mpegts @ 0000023bec450540] Could not find codec parameters for stream 4 (Subtitle: hdmv_pgs_subtitle (pgssub) ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0000023bec450540] Could not find codec parameters for stream 5 (Subtitle: hdmv_pgs_subtitle (pgssub) ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0000023bec450540] Could not find codec parameters for stream 6 (Subtitle: hdmv_pgs_subtitle (pgssub) ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0000023bec450540] Could not find codec parameters for stream 7 (Subtitle: hdmv_pgs_subtitle (pgssub) ([144][0][0][0] / 0x0090)): unspecified size
Input #0, mpegts, from 'C:\D\Dolby-Vision-Tools\afgm-00001.ts':
  Duration: 02:18:01.28, start: 11.645667, bitrate: 54956 kb/s
  Program 1
  Stream #0:0[0x1011]: Video: hevc (Main 10) (HDMV / 0x564D4448), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 90k tbn
  Stream #0:1[0x1100](eng): Audio: truehd (AC-3 / 0x332D4341), 48000 Hz, 7.1, s32 (24 bit)
  Stream #0:2[0x1100]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, 5.1(side), fltp, 640 kb/s
  Stream #0:3[0x12a0](eng): Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
  Stream #0:4[0x12a1](eng): Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
  Stream #0:5[0x12a2](eng): Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
  Stream #0:6[0x12a3](eng): Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
  Stream #0:7[0x12a4](eng): Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Output #0, matroska, to 'I:\TEMP\chunk.mkv':
  Metadata:
    encoder         : Lavf59.16.100
  Stream #0:0: Video: hevc (Main 10) (HDMV / 0x564D4448), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160 [SAR 1:1 DAR 16:9], q=2-31, 23.98 fps, 23.98 tbr, 1k tbn
  Stream #0:1(eng): Audio: truehd ([255][255][255][255] / 0xFFFFFFFF), 48000 Hz, 7.1, s32 (24 bit)
Stream mapping:
  Stream #0:0 -> #0:0 (copy)
  Stream #0:1 -> #0:1 (copy)
Press [q] to stop, [?] for help
frame= 7175 fps=917 q=-1.0 Lsize= 2081513kB time=00:05:00.00 bitrate=56839.2kbits/s speed=38.3x
video:1908797kB audio:170105kB subtitle:0kB other streams:0kB global headers:1kB muxing overhead: 0.125547%
Measuring the HDR10 video letterbox...
min: 0.0050 cd/m2, max: 4000 cd/m2
tsMuxeR version git-f4fa419. github.com/justdan96/tsMuxer
100.0% complete
Processed 0 video frames
100.0% complete
Flushing write buffer
Demux complete.
Demuxing time: 14 sec
SMPTE ST 2086
HDR10plus metadata not present. Generating DoVi from HDR10 with madVR...
Measuring video file "C:\D\Dolby-Vision-Tools\afgm-00001.ts" using D3D11 (native)...
Metadata:
  Mastering display luminance: 0.005/4000, gamut: 0.68 0.32, 0.15 0.06, 0.265 0.69, 0.3127 0.329
  MaxCLL: 10000, MaxFALL: 424 nits
Measurements:
  Frames: 198552, MaxCLL 100%: 9500, 99.9%: 5486, MaxFALL: 419, AvgFALL: 23, AvgFMLL: 944 nits
Parsing madVR measurement file...
Generating metadata: Profile 8.1 (HDR10)...
Generated metadata for 198552 frames
Done.
EditConfig {
    mode: 0,
    remove_cmv4: false,
    remove_mapping: false,
    active_area: Some(
        ActiveArea {
            crop: false,
            drop_l5: None,
            presets: Some(
                    ActiveAreaOffsets {
                        left: 0,
                        right: 0,
                        top: 280,
                        bottom: 280,
            edits: Some(
                    "all": 0,
    remove: None,
    duplicate: None,
    min_pq: None,
    max_pq: None,
    level6: None,
    level9: None,
    level11: None,
Parsing RPU file...
Editing active area offsets...
Final metadata length: 198552
Writing RPU file...
EditConfig {
    mode: 0,
    remove_cmv4: false,
    active_area: None,
    remove: None,
    duplicate: None,
    min_pq: None,
    max_pq: None,
    level6: Some(
        ExtMetadataBlockLevel6 {
            max_display_mastering_luminance: 4000,
            min_display_mastering_luminance: 50,
            max_content_light_level: 10000,
            max_frame_average_light_level: 424,
    level9: None,
    level11: None,
Parsing RPU file...
Writing RPU file...
"left": 0
"right": 0
"top": 280
"bottom": 280
MDL.max: 4000
MDL.min: 50
Maxcll: 10000
Maxfall: 424
Display P3
injecting RPU-L6-L5.bin ...
Parsing RPU file...
Processing input video for frame order info...
Warning: mismatched lengths. video 0, RPU 198552
Metadata will be skipped at the end to match video length
Rewriting file with interleaved RPU NALs..
Parsing RPU file...
  "dovi_profile": 8,
  "header": {
    "rpu_nal_prefix": 25,
    "rpu_type": 2,
    "rpu_format": 18,
    "vdr_rpu_profile": 1,
    "vdr_rpu_level": 0,
    "vdr_seq_info_present_flag": true,
    "chroma_resampling_explicit_filter_flag": false,
    "coefficient_data_type": 0,
    "coefficient_log2_denom": 23,
    "vdr_rpu_normalized_idc": 1,
    "bl_video_full_range_flag": false,
    "bl_bit_depth_minus8": 2,
    "el_bit_depth_minus8": 2,
    "vdr_bit_depth_minus_8": 4,
    "spatial_resampling_filter_flag": false,
    "reserved_zero_3bits": 0,
    "el_spatial_resampling_filter_flag": false,
    "disable_residual_flag": true,
    "vdr_dm_metadata_present_flag": true,
    "use_prev_vdr_rpu_flag": false,
    "prev_vdr_rpu_id": 0,
    "vdr_rpu_id": 0,
    "mapping_color_space": 0,
    "mapping_chroma_format_idc": 0,
    "num_pivots_minus_2": [
      0,
      0,
      0
    "pred_pivot_value": [
        0,
        1023
        0,
        1023
        0,
        1023
    "nlq_method_idc": null,
    "nlq_num_pivots_minus2": null,
    "nlq_pred_pivot_value": null,
    "num_x_partitions_minus1": 0,
    "num_y_partitions_minus1": 0
  "rpu_data_mapping": {
    "mapping_idc": [
        0
        0
        0
    "mapping_param_pred_flag": [
        false
        false
        false
    "num_mapping_param_predictors": [
        0
        0
        0
    "diff_pred_part_idx_mapping_minus1": [
    "poly_order_minus1": [
        0
        0
        0
    "linear_interp_flag": [
        false
        false
        false
    "pred_linear_interp_value_int": [
    "pred_linear_interp_value": [
    "poly_coef_int": [
          0,
          1
          0,
          1
          0,
          1
    "poly_coef": [
          0,
          0
          0,
          0
          0,
          0
    "mmr_order_minus1": [
    "mmr_constant_int": [
    "mmr_constant": [
    "mmr_coef_int": [
    "mmr_coef": [
  "vdr_dm_data": {
    "compressed": false,
    "affected_dm_metadata_id": 0,
    "current_dm_metadata_id": 0,
    "scene_refresh_flag": 0,
    "ycc_to_rgb_coef0": 9574,
    "ycc_to_rgb_coef1": 0,
    "ycc_to_rgb_coef2": 13802,
    "ycc_to_rgb_coef3": 9574,
    "ycc_to_rgb_coef4": -1540,
    "ycc_to_rgb_coef5": -5348,
    "ycc_to_rgb_coef6": 9574,
    "ycc_to_rgb_coef7": 17610,
    "ycc_to_rgb_coef8": 0,
    "ycc_to_rgb_offset0": 16777216,
    "ycc_to_rgb_offset1": 134217728,
    "ycc_to_rgb_offset2": 134217728,
    "rgb_to_lms_coef0": 7222,
    "rgb_to_lms_coef1": 8771,
    "rgb_to_lms_coef2": 390,
    "rgb_to_lms_coef3": 2654,
    "rgb_to_lms_coef4": 12430,
    "rgb_to_lms_coef5": 1300,
    "rgb_to_lms_coef6": 0,
    "rgb_to_lms_coef7": 422,
    "rgb_to_lms_coef8": 15962,
    "signal_eotf": 65535,
    "signal_eotf_param0": 0,
    "signal_eotf_param1": 0,
    "signal_eotf_param2": 0,
    "signal_bit_depth": 12,
    "signal_color_space": 0,
    "signal_chroma_format": 0,
    "signal_full_range_flag": 1,
    "source_min_pq": 62,
    "source_max_pq": 3696,
    "source_diagonal": 42,
    "cmv29_metadata": {
      "num_ext_blocks": 3,
      "ext_metadata_blocks": [
          "Level1": {
            "min_pq": 0,
            "max_pq": 2962,
            "avg_pq": 1447
          "Level5": {
            "active_area_left_offset": 0,
            "active_area_top_offset": 280,
            "active_area_bottom_offset": 280
          "Level6": {
            "max_display_mastering_luminance": 4000,
            "min_display_mastering_luminance": 50,
            "max_content_light_level": 10000,
            "max_frame_average_light_level": 424
    "cmv40_metadata": {
          "Level9": {
            "length": 1,
            "source_primary_index": 0
          "Level11": {
            "content_type": 1,
            "whitepoint": 0,
            "reference_mode_flag": true,
            "reserved_byte2": 0,
            "reserved_byte3": 0
          "Level254": {
            "dm_mode": 0,
            "dm_version_index": 2
  "rpu_data_crc32": 1435246839
"The script has completed."
#6722 Post by RESET_9999 » Thu Jun 16, 2022 10:55 am
dwalme wrote: Thu Jun 16, 2022 4:17 am
looks like everything went fine.
You can ignore the ffmpeg warnings in the beginning because, in the "auto L5" workflows, detectborder.exe(letterbox measurer) doesnt work with TS/M2TS input so I use ffmpeg to split and mux a 5 min MKV samples and I can see that your L5 was correctly measured.
ArArdin
#6723 Post by ArArdin » Thu Jun 16, 2022 12:15 pm
@RESET_9999
My apologies if this has been answered earlier. As for your tools folder, can you enlighten me as to what the "dovi_tool.fix.exe" file does?
#6724 Post by RESET_9999 » Thu Jun 16, 2022 12:20 pm
ArArdin wrote: Thu Jun 16, 2022 12:15 pm @RESET_9999
I use it to fix itunes web-dl with invalid L6 ( MDL > 10 000)
dwalme
#6725 Post by dwalme » Thu Jun 16, 2022 12:54 pm
RESET_9999 wrote: Thu Jun 16, 2022 10:55 am
I end up with a 0 byte P8_DoVi.hevc file in the output directory.
I see this warning:
I commented out the rmdir of the TEMP folder and I'm running it again to see if I can see something.
EDIT: Watching it run it seems the demux of the main HEVC track with tsMuxer is not happening correctly. I see a 0 byte *.track_4117_und.hevc in the TEMP dir. I think after tsMuxeR says 100% complete that this would be the full video HEVC.
Only takes 14 sec
100.0% complete
100.0% complete
Demux complete.
#6726 Post by RESET_9999 » Thu Jun 16, 2022 1:11 pm
I don't know, I can't reproduce with the sample i tried. Let me try a complete movie.
Drag and drop your HDR10 or HDR10plus MKV/MP4/TS file and press enter...D:\hdr10.ts
Input #0, mpegts, from 'D:\hdr10.ts':
  Duration: 00:07:08.39, start: 4200.000000, bitrate: 39049 kb/s
  Program 1
  Stream #0:0[0x1015](und): Video: hevc (Main 10) (HDMV / 0x564D4448), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160, 23.98 fps, 23.98 tbr, 90k tbn
    Side data:
      DOVI configuration record: version: 1.0, profile: 8, level: 6, rpu flag: 1, el flag: 0, bl flag: 1, compatibility id: 1
Output #0, matroska, to 'D:\TEMP\chunk.mkv':
  Metadata:
  Stream #0:0(und): Video: hevc (Main 10) (HDMV / 0x564D4448), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160, q=2-31, 23.98 fps, 23.98 tbr, 1k tbn
    Side data:
Stream mapping:
frame= 6946 fps=882 q=-1.0 Lsize= 1387475kB time=00:04:59.96 bitrate=37891.5kbits/s speed=38.1x
video:1387407kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.004931%
min: 0.0001 cd/m2, max: 1000 cd/m2
HEVC muxing fps is not set. Get fps from stream. Value: 23.976
B-pyramid level 1 detected. Shift DTS to 2 frames
99.0% complete
Processed 10273 video frames
100.0% complete
Demux complete.
Demuxing time: 4 sec
Dolby Vision / SMPTE ST 2086
Measuring video file "D:\hdr10.ts" using D3D11 (native)...
Metadata:
  Mastering display luminance: 0.0001/1000, gamut: 0.68 0.32, 0.15 0.06, 0.265 0.69, 0.3127 0.329
  MaxCLL: 0, MaxFALL: 0 nits
Measurements:
  Frames: 10271, MaxCLL 100%: 623, 99.9%: 598, MaxFALL: 250, AvgFALL: 44, AvgFMLL: 416 nits
Generated metadata for 10271 frames
Done.
EditConfig {
    mode: 0,
    remove_cmv4: false,
    active_area: Some(
        ActiveArea {
            crop: false,
            drop_l5: None,
            presets: Some(
                    ActiveAreaOffsets {
                        left: 0,
                        right: 0,
                        top: 276,
                        bottom: 276,
            edits: Some(
                    "all": 0,
    remove: None,
    duplicate: None,
    min_pq: None,
    max_pq: None,
    level6: None,
    level9: None,
    level11: None,
Parsing RPU file...
Final metadata length: 10271
Writing RPU file...
EditConfig {
    mode: 0,
    remove_cmv4: false,
    active_area: None,
    remove: None,
    duplicate: None,
    min_pq: None,
    max_pq: None,
    level6: Some(
            max_display_mastering_luminance: 1000,
            min_display_mastering_luminance: 1,
            max_content_light_level: 0,
            max_frame_average_light_level: 0,
    level9: None,
    level11: None,
Parsing RPU file...
Writing RPU file...
"left": 0
"right": 0
"top": 276
"bottom": 276
MDL.max: 1000
MDL.min: 1
Maxcll: 0
Maxfall: 0
Display P3
Parsing RPU file...
Warning: Input file already has RPUs, they will be replaced.
Warning: mismatched lengths. video 10274, RPU 10271
Metadata will be duplicated at the end to match video length
Parsing RPU file...
  "dovi_profile": 8,
  "header": {
    "rpu_type": 2,
    "rpu_format": 18,
    "vdr_rpu_level": 0,
    "vdr_rpu_id": 0,
      0,
      0,
      0
        0,
        1023
        0,
        1023
        0,
        1023
    "mapping_idc": [
        0
        0
        0
        false
        false
        false
        0
        0
        0
        0
        0
        0
        false
        false
        false
    "poly_coef_int": [
          0,
          1
          0,
          1
          0,
          1
    "poly_coef": [
          0,
          0
          0,
          0
          0,
          0
    "mmr_constant": [
    "mmr_coef_int": [
    "mmr_coef": [
  "vdr_dm_data": {
    "source_min_pq": 7,
    "source_max_pq": 3079,
    "cmv29_metadata": {
          "Level1": {
            "min_pq": 0,
            "max_pq": 2708,
            "avg_pq": 1141
          "Level5": {
            "active_area_top_offset": 276,
            "active_area_bottom_offset": 276
          "Level6": {
            "max_content_light_level": 0,
            "max_frame_average_light_level": 0
    "cmv40_metadata": {
          "Level9": {
            "length": 1,
          "Level11": {
            "content_type": 1,
            "whitepoint": 0,
            "reserved_byte3": 0
          "Level254": {
            "dm_mode": 0,
  "rpu_data_crc32": 867262424
#6727 Post by RESET_9999 » Thu Jun 16, 2022 1:37 pm
Ha, I know why. It's related to tsmuxer track id 4117 vs 4113...
will upload a new version soon...
#6728 Post by RESET_9999 » Thu Jun 16, 2022 2:24 pm
dwalme wrote: Thu Jun 16, 2022 12:54 pm
please try 1.3.9
dwalme
#6729 Post by dwalme » Thu Jun 16, 2022 3:07 pm
RESET_9999 wrote: Thu Jun 16, 2022 2:24 pm
please try 1.3.9
1.3.9 works now. Thank you.
mad83
#6730 Post by mad83 » Mon Jun 20, 2022 11:56 am
please try 1.3.9
Hi RESET_9999,
Is there any option available for your tool to convert web-dl p5 to HDR10 Plus?
mad83
#6731 Post by mad83 » Mon Jun 20, 2022 12:04 pm
@RESET_9999
Could it be possible to use your tool to combine HDR10+ with DolbyVision in one file, for example:
web-dl.HDR.2160p
web-dl.DV.2160p
final version would be:
new.web-dl.2160p.HDR.DV
#6732 Post by RESET_9999 » Mon Jun 20, 2022 1:31 pm
mad83 wrote: Mon Jun 20, 2022 11:56 am Is there any option available for your tool to convert web-dl p5 to HDR10 Plus?
No, I could be wrong but I don't think it's possible to convert DV to HDR10plus yet.
mad83 wrote: Mon Jun 20, 2022 12:04 pm Could it be possible to use your tool to combine HDR10+ with DolbyVision in one file, for example:
If your base layer is HDR10plus, you can inject DV and HDR10plus will be preserved.
If you have an HDR10plus JSON metadata, you can inject it with my script (assuming it's in sync) and then, inject DV.
MODE.M --> MODE.6= HDR10plus INJECTOR
dwalme
#6733 Post by dwalme » Mon Jun 20, 2022 1:56 pm
RESET_9999 wrote: Mon Jun 20, 2022 1:31 pm
If you measure HDR10 with MadVR can you inject HDR10Plus and DV at the same time?
#6734 Post by RESET_9999 » Mon Jun 20, 2022 2:10 pm
dwalme wrote: Mon Jun 20, 2022 1:56 pm If you measure HDR10 with MadVR can you inject HDR10Plus and DV at the same time?
At the same time no, there's only one mode that can inject HDR10plus. I don't have any hardware that supports HDR10plus so I don't care much about it personally.
If you have HDR10plus metadata, why do you want to measure HDR10 with madvr? Just convert HDR10plus to DoVi.
madvr dovi generation should only be used if you don't have any DV/hdr10plus source (or if the source luminance doesn't match).
dwalme
#6735 Post by dwalme » Mon Jun 20, 2022 2:17 pm
RESET_9999 wrote: Mon Jun 20, 2022 2:10 pm
In my example there is no HDR10+ information.
I am measuring many of my HDR10 movies with MadVR and creating DoVi Profile 8.1 files. Figured there would be no downside to also create HDR10+ metadata and inject at the same time for the most versatile files if that were possible.
I had a Samsung TV for a short time. HDR10+ would have been a benefit then.
