Hey
Re: Hey
You say "doesn't work", but you don't say what you did.
Did you use the new key from the website, or from the software download?
Re: Hey
You got the key from viewtopic.php?f=5&t=1053 , correct? That should be the current key, issued two months after the key in the original file.
Re: Hey
What exact message are you getting? The current key (from the message) is good through the end of July, and 1.16.7 should accept it. What you're describing should not be happening.
