Wow, they've made this one confusing! 402 versions, all with different segments maps! Any ideas which is the correct one please?
Film Stars Don't Die In Liverpool (UK Blu Ray)
Re: Film Stars Don't Die In Liverpool (UK Blu Ray)
I did submit the disk info to mike as described in http://www.makemkv.com/forum2/viewtopic.php?f=8&t=14330
guyonphone wrote:793
Awesome, thank you
FIX Is Below
Thanks 793 - it definitely isn't 00000
Here you go guys this Fix I made will make the Film 100% playable Film Stars Don't Die In Liverpool
Found The Retail PLAYLIST [?.MPLS] In DVDFAB 11
Lots Of Sneaky Shit Going On With The PLAYLISTS So I
Used My Trusty [*.Bat File] - You Must Change All Supplied MPLS
[Film Stars Don't Die In Liverpool (U.K) Retail Version VIA DVDFAB 11]
Just Change All Playlists In The [Liverpool-313.rar] File To PLAYLIST FOLDER &
BACKUP\PLAYLIST FOLDER
All Menus Work 100% AND In Film Popups - Once the Blu-ray is working then you can make an MKV
- [Film Stars Don't Die In Liverpool.rar
- Flim FIX
- (4.74 KiB) Downloaded 386 times
