Wow, they've made this one confusing! 402 versions, all with different segments maps! Any ideas which is the correct one please?
Film Stars Don't Die In Liverpool (UK Blu Ray)
paulcummin
guyonphone
Re: Film Stars Don't Die In Liverpool (UK Blu Ray)
I did submit the disk info to mike as described in http://www.makemkv.com/forum2/viewtopic.php?f=8&t=14330
paulcummin
guyonphone wrote:793
Awesome, thank you
Steveredrum
FIX Is Below
Thanks 793 - it definitely isn't 00000
Steveredrum
Here you go guys this Fix I made will make the Film 100% playable Film Stars Don't Die In Liverpool
Found The Retail PLAYLIST [?.MPLS] In DVDFAB 11
Lots Of Sneaky Shit Going On With The PLAYLISTS So I
Used My Trusty [*.Bat File] - You Must Change All Supplied MPLS
[Film Stars Don't Die In Liverpool (U.K) Retail Version VIA DVDFAB 11]
Just Change All Playlists In The [Liverpool-313.rar] File To PLAYLIST FOLDER &
BACKUP\PLAYLIST FOLDER
All Menus Work 100% AND In Film Popups - Once the Blu-ray is working then you can make an MKV
- [Film Stars Don't Die In Liverpool.rar
- Flim FIX
- (4.74 KiB) Downloaded 512 times
