Hey
lowrider291
Hey
#1 Post by lowrider291 » Thu Jun 16, 2022 7:06 pm
i tried to do the beta key but it didn't work for me. What am i doing wrong?
Re: Hey
#2 Post by Woodstock » Thu Jun 16, 2022 8:18 pm
You say "doesn't work", but you don't say what you did.
Did you use the new key from the website, or from the software download?
lowrider291
Re: Hey
#3 Post by lowrider291 » Fri Jun 17, 2022 1:14 am
I got the key from this site. I just copied and paste it in the registration i got a message saying invalid
Re: Hey
#4 Post by Woodstock » Fri Jun 17, 2022 2:46 am
You got the key from viewtopic.php?f=5&t=1053 , correct? That should be the current key, issued two months after the key in the original file.
lowrider291
Re: Hey
#5 Post by lowrider291 » Fri Jun 17, 2022 3:04 am
yes i did i also just tried it again still didn't work
Re: Hey
#6 Post by Woodstock » Fri Jun 17, 2022 1:38 pm
What exact message are you getting? The current key (from the message) is good through the end of July, and 1.16.7 should accept it. What you're describing should not be happening.
lowrider291
Re: Hey
#7 Post by lowrider291 » Fri Jun 17, 2022 8:28 pm
it says invalid an i can't hit ok
jinx100
Re: Hey
#8 Post by jinx100 » Fri Jun 17, 2022 11:52 pm
You probably already saw this but a double click will not copy the entire code due to the second character "-". Use a triple click to get the full key.
lowrider291
Re: Hey
#9 Post by lowrider291 » Sat Jun 18, 2022 12:39 am
thanks so much that worked!!
