Hey
lowrider291
Hey
Post by lowrider291 »
i tried to do the beta key but it didn't work for me. What am i doing wrong?
Re: Hey
You say "doesn't work", but you don't say what you did.
Did you use the new key from the website, or from the software download?
lowrider291
Re: Hey
I got the key from this site. I just copied and paste it in the registration i got a message saying invalid
Re: Hey
You got the key from viewtopic.php?f=5&t=1053 , correct? That should be the current key, issued two months after the key in the original file.
lowrider291
Re: Hey
yes i did i also just tried it again still didn't work
Re: Hey
What exact message are you getting? The current key (from the message) is good through the end of July, and 1.16.7 should accept it. What you're describing should not be happening.
lowrider291
Re: Hey
it says invalid an i can't hit ok
jinx100
Re: Hey
Post by jinx100 »
You probably already saw this but a double click will not copy the entire code due to the second character "-". Use a triple click to get the full key.
lowrider291
Re: Hey
thanks so much that worked!!
