New Intel Chips
centuryx476
New Intel Chips
Post by centuryx476 » Sat Jan 15, 2022 10:22 pm
Apparently Intel is taking out SGX on the new generation of chips. This is needed for blu-ray playback.
Does this have any effect on makemkv and ripping ?
Source: https://www.bleepingcomputer.com/news/s ... precation/
Thank You
Re: New Intel Chips
Post by dcoke22 » Sun Jan 16, 2022 12:11 am
centuryx476 wrote: Sat Jan 15, 2022 10:22 pm Does this have any effect on makemkv and ripping ?
No, I don't think so. MakeMKV works just fine on AMD CPUs, which also don't have SGX.
Re: New Intel Chips
Post by Woodstock » Sun Jan 16, 2022 12:23 am
Actually, it's needed for OFFICIALLY LICENSED SOFTWARE that plays UHD video right from the disk.
Unofficial software has no need for SGX.
Have to wonder if the OFFICIALLY LICENSED SOFTWARE will opt to simply not try to hide the DRM code in SGX to maintain their market going forward.
centuryx476
Re: New Intel Chips
Post by centuryx476 » Sun Jan 16, 2022 12:24 am
Wonderful.
I just wanted to be sure that we can keep on doing what we have been doing!
exitguy
Re: New Intel Chips
Post by exitguy » Sun Jan 16, 2022 12:34 am
centuryx476 wrote: Sun Jan 16, 2022 12:24 am Wonderful.
Simple, just keep an old PC with MakeMKV on it and use an external drive that can be swapped between machines.
Re: New Intel Chips
Post by dcoke22 » Sun Jan 16, 2022 12:41 am
exitguy wrote: Sun Jan 16, 2022 12:34 am Simple, just keep an old PC with MakeMKV on it and use an external drive that can be swapped between machines.
You don't need an old PC. MakeMKV doesn't need Intel SGX to work at all. MakeMKV works on AMD CPUs, Apple Silicon CPUs and ARM CPUs (in the Raspberry Pi) and none of them have Intel SGX.
As Woodstock said, the only thing you need Intel SGX for is to use officially licensed UHD playback software to play a UHD on an official UHD drive.
Re: New Intel Chips
Post by Billycar11 » Sun Jan 16, 2022 12:42 am
Woodstock wrote: Sun Jan 16, 2022 12:23 am
Already happened sadly but they didn't opt not to hide it they just got rid of it.
viewtopic.php?f=16&t=26737&p=115969#p115969
nizmoz
Re: New Intel Chips
Post by nizmoz » Mon Jan 17, 2022 10:24 pm
sandersoni
Re: New Intel Chips
Post by sandersoni » Thu Jan 27, 2022 2:07 pm
Cyberlink software won't play 4K UHD Blu rays anymore on new processors.
https://www.whathifi.com/news/intel-dis ... t-pc-chips
midnighwatcher
Re: New Intel Chips
Post by midnighwatcher » Mon Jun 13, 2022 2:31 am
To confirm, the new Intel CPUs work well with MakeMKV, correct?
Re: New Intel Chips
Post by Billycar11 » Mon Jun 13, 2022 2:55 am
midnighwatcher wrote: Mon Jun 13, 2022 2:31 am To confirm, the new Intel CPUs work well with MakeMKV, correct?
yes you never needed sgx for makekmv to work thats whats removed in the new chips
Rumourd
Re: New Intel Chips
Post by Rumourd » Wed Jun 15, 2022 3:08 am
Everyone should be using VLC as a player anyway. It plays everything, and UHD isn't washed out.
