Dual layer DV to single with command line
purpl3F0x
Post by purpl3F0x » Mon Jun 13, 2022 2:12 pm
Hello, I used makemkv on windows to convert a dual layer Dolby Vision .mkv file to single layer, for using it on Plex and worked fine.
I would like to ask if it's possible to do this operation also via command line ?
Re: Dual layer DV to single with command line
Post by dcoke22 » Mon Jun 13, 2022 6:15 pm
https://makemkv.com/developers/
That'll get you started using the command line interface.
purpl3F0x
Post by purpl3F0x » Tue Jun 14, 2022 3:58 am
I have looked into that but I haven't figured out how to do it. Can you give me an example how to pass an mkv file as input ?
Post by dcoke22 » Tue Jun 14, 2022 1:29 pm
There are a bunch of threads on this topic on the forum. Just look around. For example: complete documentation for makemkvcon?
purpl3F0x
Post by purpl3F0x » Tue Jun 14, 2022 3:39 pm
I have looked into that but still can't pass an mkv file to it. For example
makemkvconv info file:"a_file.mkv"
seems to work as expected.
But:
Gives the following
MakeMKV v1.16.7 win(x64-release) started
The program can't find any usable optical drives.
Use: makemkvcon [switches] Command [Parameters]
