Doesn't work
bkarlan
Doesn't work
Post by bkarlan »
Keeps asking for access to everything. It wants access to my calender, my tasks, my downloads folder (which is fine), but it also want access to the files in the downloads folder. Then when you choose yes or no to the questions, it goes into a loop where you grant access to the downloads folder and it asks again for access to the downloads folder and it asks again for access to the downloads folder, and it keeps asking regardless of whether or not you choose ok or not. I can only run this in Fedora on a VM in Parallels.
Re: Doesn't work
MakeMKV should not ask to access your calendar or other tasks. It should only ask to access your DVD/BD drive and possibly the location you're intending to write files to.
