There's some good info in there. I'm surprised the Shield supports it.
must be an LLDV thing because nothing on my Shield for L8 in tv-led DV.
Well your TV doesn't support it either, so it makes sense.
ha yes, because in LLDV the player does the tonemapping. I didnt think of that. Will test again once i get my C2 soonish
deadchip12
Do you think this is a good solution to share the external hard drive that contains movie files between the x700 and the pc?
https://www.amazon.com/UGREEN-Selector- ... B01MXXQKGM
Press one button to switch to pc, copy and paste the bmdv folder to root, press the button to switch back to x700, watch the movie. Save the time from the constant unplugging/replugging when you want to change movies.
sounds like a good idea. let us know if it works.
BadSector81
Hi all! Please help me. I'd like to edit L5 for frames between 0-2117 and 2590-4428. Can I make it with one JASON or I should use two? One for 0-2117 and one for 2590-4428? Thanks!
I assume all the frames within each group will have the same edits. i.e. 0-2117 0,0,0,0 and 2590-4428 0,0,280,280. If so, yes one .json should work.BadSector81 wrote: ↑Thu Jun 09, 2022 4:26 pmHi all! Please help me. I'd like to edit L5 for frames between 0-2117 and 2590-4428. Can I make it with one JASON or I should use two? One for 0-2117 and one for 2590-4428? Thanks!
More reasons to collect physical media. Ugoos AM6B+.
deadchip12
One thing I'm worried is that connecting through the switch may cut down on the usb 2.0 speed and affect the bitrate of the movie. Is there a way to tell if a movie is not playing at maximum bitrate?
it cant live cutdown the bit rate if there are problems it would be stutters a read speed of about 12MBs should be enough for any UHD usb 2 can do about 40MBs in real world usedeadchip12 wrote: ↑Fri Jun 10, 2022 5:33 amOne thing I'm worried is that connecting through the switch may cut down on the usb 2.0 speed and affect the bitrate of the movie. Is there a way to tell if a movie is not playing at maximum bitrate?
deadchip12
Has anyone tried playing the Dolby Amaze and Leaf demo file? I'm playing them on my x700 connected to the denon x3700h but there's no sound. They are originally mkv files and I converted them to ts but still no sound.
truehd sound? it needs an ac3 core.deadchip12 wrote: ↑Fri Jun 10, 2022 11:05 amHas anyone tried playing the Dolby Amaze and Leaf demo file? I'm playing them on my x700 connected to the denon x3700h but there's no sound. They are originally mkv files and I converted them to ts but still no sound.
deadchip12
Hmm so the x700 can't play that...RESET_9999 wrote: ↑Fri Jun 10, 2022 11:20 amtruehd sound? it needs an ac3 core.deadchip12 wrote: ↑Fri Jun 10, 2022 11:05 amHas anyone tried playing the Dolby Amaze and Leaf demo file? I'm playing them on my x700 connected to the denon x3700h but there's no sound. They are originally mkv files and I converted them to ts but still no sound.
Is there any other way to play these files?
you just need to add the core back into TrueHD, nothing new and it's been explained many many times in this thread. . you can do that with eac3to or thdmerge.deadchip12 wrote: ↑Fri Jun 10, 2022 11:37 amHmm so the x700 can't play that...
or with my script:
I tried Ugoos AM6B Plus (S922X-J), it only handles L1 and L2.RESET_9999 wrote: ↑Wed Jun 08, 2022 6:53 pmSo the appleTV really only supports P5 dynamic metadata...NiCE77 wrote: ↑Wed Jun 08, 2022 6:44 pmMany thanks, I've tested, but none of the trims work with Apple TV 4K 2021. I checked both in native and LLDV mode.
I checked it with more players and TVs, and the results are here: https://onedrive.live.com/view.aspx?res ... Vgr1mbxiSQ
Do you still have the GTV Chromecast ? is L2 working in LLDV?
You're the second person to say the Shield has no L2 response in LLDV.
