Newbie question about MKV and Dolby Vision playback
ben_uk
#1 Post by ben_uk » Thu Jun 09, 2022 5:15 pm
I don’t know a great deal about Dolby Vision and MKV files however I was told that it’s possible for MKV files to retain Dolby Vision functionality? Can I just ask, is anything specific required from the user end to ensure that files are created with this layer intact?
Thanks so much,
Ben.
Re: Newbie question about MKV and Dolby Vision playback
#2 Post by dcoke22 » Fri Jun 10, 2022 11:58 pm
The most recent versions of MakeMKV will retain this information by default in the resulting .mkv file. That you have any devices that can play it back is another matter.
If you rip a UHD and examine the resulting .mkv with a program like MediaInfo, you should see something that looks like the following:
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
The exact details of the HDR format line will change according to whatever HDR format your UHD has. The example above shows a profile 7 Dolby Vision title that's HDR10+ compatible.
awdspyder
#3 Post by awdspyder » Fri Jul 01, 2022 2:27 am
As mentioned, just ripping the video track with the latest version of MakeMKV will retain the DV metadata. I strongly recommend the Nvidia Shield Pro (not the "tube") as a playback device for DV MKVs. I'm using Emby to serve up the media, but Plex should work as well.
