keys not found - not sure i buy it
cantonhero
Post by cantonhero » Thu Jun 09, 2022 1:42 pm
Hi gang. I recently got set up for creating UHD backups and the first 3 discs I tried all said 'volume key is unknown for this disc' which I find hard to believe given that they're not exactly brand new releases:
Top Gun (5/19/20)
Dune (original) (8/31/21)
Scream (remake) (4/5/22)
Can anyone confirm if these keys should in fact be known? Any suggestions? Thanks in advance!!
Drive Information (if it helps):
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.01
Bus encryption flags: 1F
Highest AACS version: 76
Re: keys not found - not sure i buy it
Post by Billycar11 » Thu Jun 09, 2022 1:50 pm
Top Gun (5/19/20)
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.01
You can confirm it by using my keys linked in guide
Post by d00zah » Thu Jun 09, 2022 2:34 pm
Top Gun (5/19/20)
From the UHD FAQ (a worthwhile read):
I see a movie discussed in the forum, but MakeMKV won't open my disc.
There are multiple versions of UHDs for each movie (countries, retailers, rentals) and there may be multiple keys for even the same version, so it's possible that your particular disc isn't decrypted yet. Submit the dump file!
cantonhero
Post by cantonhero » Thu Jun 09, 2022 2:55 pm
thanks guys, will do some reading
Krawk
Post by Krawk » Tue Jun 14, 2022 8:12 pm
Which guide? I see no keys.
Post by d00zah » Tue Jun 14, 2022 8:25 pm
Refer to the Useful Links section of "the guide".
cantonhero
Post by cantonhero » Wed Jul 06, 2022 7:01 pm
thanks @d00zah - I did not have my preference to enable internet access checked.
