Hi gang. I recently got set up for creating UHD backups and the first 3 discs I tried all said 'volume key is unknown for this disc' which I find hard to believe given that they're not exactly brand new releases:
Top Gun (5/19/20)
Dune (original) (8/31/21)
Scream (remake) (4/5/22)
Can anyone confirm if these keys should in fact be known? Any suggestions? Thanks in advance!!
Drive Information (if it helps):
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.01
Bus encryption flags: 1F
Highest AACS version: 76
keys not found - not sure i buy it
Re: keys not found - not sure i buy it
You can confirm it by using my keys linked in guidecantonhero wrote: Thu Jun 09, 2022 1:42 pm Hi gang. I recently got set up for creating UHD backups and the first 3 discs I tried all said 'volume key is unknown for this disc' which I find hard to believe given that they're not exactly brand new releases:
Top Gun (5/19/20)
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.01
From the UHD FAQ (a worthwhile read):cantonhero wrote: Thu Jun 09, 2022 1:42 pm Hi gang. I recently got set up for creating UHD backups and the first 3 discs I tried all said 'volume key is unknown for this disc' which I find hard to believe given that they're not exactly brand new releases:
Top Gun (5/19/20)
I see a movie discussed in the forum, but MakeMKV won't open my disc.
There are multiple versions of UHDs for each movie (countries, retailers, rentals) and there may be multiple keys for even the same version, so it's possible that your particular disc isn't decrypted yet. Submit the dump file!
cantonhero
thanks guys, will do some reading
Which guide? I see no keys.
cantonhero
thanks @d00zah - I did not have my preference to enable internet access checked.
