Hi guys,
I downgraded my BH16NS55 to firmware 1.02,but it seems that something is not right.
Below you can see the current situation.
Any help would be much appriciated.
LG BH16NS55 flashed but not working
panospav
emrysblack
Re: LG BH16NS55 flashed but not working
Drive looks fine. It can open and read the disc. The disc read error is probably a dirty disc. Clean the disc first and retry. You may need to get a replacement disc if that doesn't work.
If you want to check the drive, try a different disc. That may indicate that you need to clean the drive itself, but 90% of the time, the disc needs to be cleaned, even if it's new and "looks clean"
panospav
Thank you,
is dead and I will replace it with a Pioneer BDR-S12UHT.
emrysblack
Sorry to hear that. Dead drives are never fun. On the plus side, that pioneer is a fantastic drive.
panospav
It is fantastic.
I can play with MPC HC and Madvr all UHD discs and of course I can rip them easily, and it is silent! No noise at all!
