LG BH16NS55 flashed but not working
panospav
#1 Post by panospav » Sat Jun 04, 2022 9:48 am
Hi guys,
I downgraded my BH16NS55 to firmware 1.02,but it seems that something is not right.
Below you can see the current situation.
Any help would be much appriciated.
Screenshot 2022-06-04 122841.png (307.82 KiB) Viewed 7725 times
Screenshot 2022-06-04 115334.png (225.66 KiB) Viewed 7725 times
Screenshot 2022-06-04 114703.png (196.81 KiB) Viewed 7725 times
emrysblack
Re: LG BH16NS55 flashed but not working
#2 Post by emrysblack » Sat Jun 04, 2022 7:27 pm
Drive looks fine. It can open and read the disc. The disc read error is probably a dirty disc. Clean the disc first and retry. You may need to get a replacement disc if that doesn't work.
If you want to check the drive, try a different disc. That may indicate that you need to clean the drive itself, but 90% of the time, the disc needs to be cleaned, even if it's new and "looks clean"
panospav
#3 Post by panospav » Tue Jun 07, 2022 9:20 am
Thank you,
is dead and I will replace it with a Pioneer BDR-S12UHT.
emrysblack
#4 Post by emrysblack » Tue Jun 07, 2022 10:22 pm
Sorry to hear that. Dead drives are never fun. On the plus side, that pioneer is a fantastic drive.
panospav
#5 Post by panospav » Fri Jun 10, 2022 9:51 am
It is fantastic.
I can play with MPC HC and Madvr all UHD discs and of course I can rip them easily, and it is silent! No noise at all!
