Allegiant
mr.ripper
Re: Allegiant
Post by mr.ripper » Thu Jun 07, 2018 11:33 am
With help of AnyDVD, VLC and Process Explorer, it looks like 00230.mpls is the correct one, but haven't watched and confirmed yet.
kimkadn
Re: Allegiant
Post by kimkadn » Sun Aug 23, 2020 9:51 am
The Nordic version of Allegiant has this corerct playlist:
Title information
Source file name: 00230.mpls
Duration: 2:00:23
Chapters count: 12
Segment count: 15
Segment map: 102,111,110,106,109,113,114,112,104,105,20,101,108,107,115
File name: title_t65.mkv
powrhaus
Re: Allegiant
Post by powrhaus » Fri Jul 30, 2021 3:48 pm
Just inserted my new copy of Allegiant I got from BestBuy in the US. I have Java installed and MakeMKV did not select the correct title. All titles were selected (there were about 300). Luckily I found this thread and was able to hopefully select the correct title. Unfortunately for some of the other movies I ripped, I simply guessed on which one was correct and will now have to figure out which movies they were so I can re-rip them.
I thought the whole point of installing Java JRE (which I did today) was to have MakeMKV figure out the correct title. Is that not the case? If it doesn't, then what does having Java installed do?
rifth427
Re: Allegiant
Post by rifth427 » Thu Oct 28, 2021 9:01 pm
I bought the three movies together in one package off amazon. (Insurgent allegiant and divergent). I am no where near figuring out which one the correct title is... as mine is not numbered the same as this posts.
For instance, my first selection looks like this
Title information
Source file name: 00010.mpls
Duration: 2:00:33
Chapters count: 16
Segment count: 20
Segment map: 513,501,520,517,511,512,503,519,502,516,510,506,515,509,508,518,505,514,504,507
File name: Allegiant_t00.mkv
and there are about 300 to choose from. Where do I start, I mean I started going through all the segment maps but EVERY one of them starts with 513. So it does not appear to match anything listed in this thread. I cannot take the time to watch every segment and match it up - sorry not gonna happen.
thetoad
Re: Allegiant
Post by thetoad » Tue Nov 02, 2021 3:06 pm
I once wrote a script (might be somewhere here) that would have makemkv enumerate all the playlists and then sort them in segment order.
one could then easily do a search to see which segments make sense following the previous one. As they are sorted, when one hits one that doesn't make sense, one can make a big jump to the next egment to try until one finds the segment that makes sense. rinse and repeat and you will end up with the correct playlist.
Re: Allegiant
Post by dcoke22 » Sun Nov 07, 2021 2:53 pm
viewtopic.php?p=99088#p99088
I think that's the post you're talking about.
thetoad
Re: Allegiant
Post by thetoad » Mon Nov 08, 2021 2:07 pm
yes.
Balefire
Re: Allegiant
Post by Balefire » Sat Feb 19, 2022 3:18 am
Axehandler wrote:
Tue Jul 12, 2016 5:41 pm
Title information
Source file name: 00838.mpls
Duration: 2:00:33
Chapters count: 16
Segment count: 20
Segment map: 513,520,501,517,511,519,512,503,502,516,510,506,518,504,515,514,508,505,509,507
File name: Allegiant_t254.mkv
This was the same segment map as I had on my copy of Allegiant from a 3-disc set bought off Amazon in 2022, though for me it was title 253.
SquishyMan
Re: Allegiant
Post by SquishyMan » Tue Jun 07, 2022 1:24 am
I have the 3 disc pack from Amazon too (purchased this year). I found the same video with the same segment map, however it was title 25 for me.
Re: Allegiant
Post by d00zah » Tue Jun 07, 2022 1:37 pm
... however it was title 25 for me.
Title count will vary depending on Preferences > Video tab > 'Minimum title length (seconds)' value.
