LibreDrive for Pioneer drives
kubtzi wrote: Wed Jun 01, 2022 6:14 am Hi,
I searched, but I'm still not sure: would the BDR-212EBK work for ripping UHD discs with LibreDrive? Or is there too much difference with the UBK version(XL vs UHD-friendly)?
Thanks for your help.
not yet but maybe soon but it would need to be flashed
kubtzi
Post by kubtzi »
Ok, thanks for the prompt answer!
ssybesma
Post by ssybesma »
Hello guys,
How do I interpret this info in the LibreDrive section below...it mentions Pioneer instead of Asus. I assume Asus just made the external case and what I have is really a Pioneer drive inside?
It says 'unpatched' so wonder if there is patched firmware for this.
Steve
OS device name: O:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
Serial number: RDDL007335WL
Firmware date: 2017-12-21
Highest AACS version: 65
Drive platform: RS8601
Firmware version: E111/ID76
emrysblack
Post by emrysblack »
It says your LibreDrive is enabled. No patching necessary. You're already good to go.
gfraw
Post by gfraw »
My drive is just throwing SCSI errors, and can't read UHDs
Info:
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-212U
Revision: 1.01
Serial number: AKDL002525WL
Firmware date: 2020-07-21
Highest AACS version: 75
Drive platform: RS8F01
Firmware version: 1.01/ID58
Sample errors:
MakeMKV v1.16.7 linux(x64-release) started
Error 'Internal error - Operation result is incorrect (132)' occurred while reading 'BD-RE PIONEER BD-RW BDR-212U 1.01 AKDL002525WL' at offset '786432'
Error 'Scsi error - NOT READY:LOGICAL UNIT NOT READY, CAUSE NOT REPORTABLE' occurred while reading 'BD-RE PIONEER BD-RW BDR-212U 1.01 AKDL002525WL' at offset '806912'
udf: node fe/efe failed!
Error 'Scsi error - NOT READY:LOGICAL UNIT NOT READY, CAUSE NOT REPORTABLE' occurred while reading 'BD-RE PIONEER BD-RW BDR-212U 1.01 AKDL002525WL' at offset '1245184'
Error 'Scsi error - NOT READY:LOGICAL UNIT NOT READY, CAUSE NOT REPORTABLE' occurred while reading 'BD-RE PIONEER BD-RW BDR-212U 1.01 AKDL002525WL' at offset '1282048'
Error 'Scsi error - NOT READY:LOGICAL UNIT NOT READY, CAUSE NOT REPORTABLE' occurred while reading 'BD-RE PIONEER BD-RW BDR-212U 1.01 AKDL002525WL' at offset '720896'
Error 'Scsi error - NOT READY:LOGICAL UNIT NOT READY, CAUSE NOT REPORTABLE' occurred while reading 'BD-RE PIONEER BD-RW BDR-212U 1.01 AKDL002525WL' at offset '1179648'
Error 'Internal error - Operation result is incorrect (132)' occurred while reading 'BD-RE PIONEER BD-RW BDR-212U 1.01 AKDL002525WL' at offset '1179648'
Error 'Scsi error - UNIT ATTENTION:POWER ON, RESET, OR BUS DEVICE RESET OCCURRED' occurred while reading 'BD-RE PIONEER BD-RW BDR-212U 1.01 AKDL002525WL' at offset '917504'
Error 'Internal error - Operation result is incorrect (132)' occurred while reading 'BD-RE PIONEER BD-RW BDR-212U 1.01 AKDL002525WL' at offset '933888'
Am I missing something?
gfraw wrote: Sun Jun 12, 2022 6:03 pm My drive is just throwing SCSI errors, and can't read UHDs
I think you had a copy & paste fail on your Sample errors section. :)
Without seeing the errors, I can say that Pioneer drives aren't immune from discs being dirty or damaged.
gfraw
Post by gfraw »
dcoke22 wrote: Mon Jun 13, 2022 12:46 pm
Yep, copy & paste fail. I updated the post above to show the errors. It is a brand-new disk, never been played before, no damage fresh from the package.
A Pio 209 can't read UHDs so far unless somebody finds a way to enable it via a modded firmware.
Ezatoka
Post by Ezatoka »
Any experiences about how well Pioneer drives (BDR-S12UHT seems to be the flagship?) handle difficult discs? E.g. read errors caused either by surface problems or because of copy protections with deliberately placed bad sectors?
gfraw wrote: Mon Jun 13, 2022 6:42 pm Yep, copy & paste fail. I updated the post above to show the errors. It is a brand-new disk, never been played before, no damage fresh from the package.
Your drive won't read any UHD discs or just this one particular disc?
I have a Pioneer BDR-212UBK (with the same firmware as yours) in a powered Vantec enclosure and it works well. What sort of enclosure is your Pioneer in? It almost seems like your drive isn't getting enough power.
crazyaoshi
Post by crazyaoshi »
Got a new Dell XPS13 9310 running Windows 11 and external drive ‎LBD-PVA6U3VBK. The brand is Logitech, which is a Japanese rebrander. It says it is UHD blu ray capable.
It looks like it is a rebranded Pioneer BDR-UD04.
Makemkv says: LibreDrive Information Status: Possible, not yet enabled Drive platform: MT1959
Do you know which libredrive firmware this is?
crazyaoshi wrote: Mon Jun 20, 2022 2:08 pm Got a new Dell XPS13 9310 running Windows 11 and external drive ‎LBD-PVA6U3VBK. The brand is Logitech, which is a Japanese rebrander. It says it is UHD blu ray capable.
What is the current firmware version on the drive?
crazyaoshi
MartyMcNuts wrote: Tue Jun 21, 2022 12:08 am
Thanks so much for the reply.
MKV says
Manufacturer: Logitec
Product: LBD USB Device
Revision: LU12
Serial number: MO3LBTF0732
Firmware date: 2121-06-21 13:45
Bus encryption flags: 1F
Highest AACS version: 68
Windows says the driver version is 10.0.22000.1.
Does this answer the question? If not, where do I find the firmware number?
crazyaoshi wrote: Tue Jun 21, 2022 1:33 pm
MKV says
Revision: LU12
Well it's not a pioneer it's some sort of LG likely a BU40N or BP60
But the good news is you can also flash that to do UHD but it is definitely not a pioneer.
If you want to risk it I would flash it to BU40N 1.03mk with enc
crazyaoshi
Billycar11 wrote: Tue Jun 21, 2022 9:59 pm
MKV says
Revision: LU12
Thank you for the reply. I downloaded the SDF flasher and all in one firmware pack, and flashed according to the instructions.
The firmware dump created something called
dump_user_Logitec_LBD_USB_Device_LU12_212106211345_MO3LBTF0732.tar
I tried flashing with BU40N from the firmware pack.
Libredrive was not enabled, and makemkv says almost nothing changed. Except, AACS was latest version 68, after the flash it was version 76.
Am I doing it wrong, using the wrong firmware, or is my drive impervious to flashing?
