BD-RE BU40N Revision: 1.04
metasynapse
Hello friends!
I have the following drive:
Product: BD-RE BU40N
Revision: 1.04
Serial number: MZ3J5KG5755
Firmware date: 2120-05-06 11:42
Highest AACS version: 66
Harware support: Yes
Firmware support: No
Firmware version: 1.04
and I don't really know how to flash exactly this version of firmware. Any ideas? Thanks in advance!
Revision: 1.04
- Just for sure :)
- IMAG0344.jpg (2.3 MiB) Viewed 42401 times
Re: BD-RE BU40N Revision: 1.04
Probably also the new encrypted type you must use the makemkv command line flasher
metasynapse
ok, thanks, but which firmware version should I use?
Well, looks like drives with the new encrypted firmware are starting to show up fairly frequently!
metasynapse
something weird just happen. Operation was successful, but firmware is still 1.04? what the heck?
- flashing.jpg (123.55 KiB) Viewed 42309 times
This might be a dumb question, but since it says ROM 1.03 on it (I assume manufactured with that) and has arrived to him with 1.04, does this mean they're upgrading the firmware at suppliers?
metasynapse
I don't see any other explanation...AffSeda wrote: Fri Jul 03, 2020 1:15 pm This might be a dumb question, but since it says ROM 1.03 on it (I assume manufactured with that) and has arrived to him with 1.04, does this mean they're upgrading the firmware at suppliers?
TeddyRaspin
Put "enc" option (without quotes) after rawflash because if your unit comes with 1.04 it will accept only fw in encrypted format.
metasynapse
It works!TeddyRaspin wrote: Fri Jul 03, 2020 3:33 pm Put "enc" option (without quotes) after rawflash because if your unit comes with 1.04 it will accept only fw in encrypted format.
TeddyRaspin
Glad to hear that.
Unrelated question:
Why are the serial numbers from MakeMKV and from the sticker different?
metasynapse
it also makes me wonder. The drive comes from a legal distribution ... I think the distributor or supplier has changed the firmware (forcibly?). This is really strange.Ezatoka wrote: Sat Jul 04, 2020 12:00 am Unrelated question:
I'd guess the number MakeMKV is displaying is actually the serial number of the drive controller / internal device, rather than the serial of the entire unit as a whole (whats on the label).
- Contact:
I think they are running some sort of upgrade process (could be recall / refurbish) where the drive gets a new firmware with encryption, and changes its serial number in a process.metasynapse wrote: Sat Jul 04, 2020 11:28 am it also makes me wonder. The drive comes from a legal distribution ... I think the distributor or supplier has changed the firmware (forcibly?). This is really strange.
Any benefit to downgrading the firmware from 1.04?
1.02 is here: https://www.lg.com/us/support/software- ... CT30011742
Is 1.03 the patched version that MakeMKV references in the LibreDrive section?
This what I have:
Revision: 1.04
Serial number: MODK5IE2313
Highest AACS version: 65
Steve
This what I have:
Revision: 1.04
Steve
