ok will add next version. good suggestion.realbabilu wrote: ↑Tue May 31, 2022 6:19 ammaybe you can add HDR10 to DV also for mp4remuxed already,
it tells if the base layer is compatible with SDR/HDR10/HLG/BD or nonerealbabilu wrote: ↑Tue May 31, 2022 6:19 amjust for curiousity: what is --dv-bl-compatible-id 1 or --dv-bl-compatible-id 2 for --dv-profile 8
but this function doesnt work with the mp4muxer I use.
