Flash a BD-RE BU40N drive - first time
outland
#1 Post by outland » Fri Jun 03, 2022 12:51 pm
So, I decided to give it a go and flash my own drive. You can see the drive (which is attached via USB enclosure) on the attached screen shots.
I'm on macOS (M1 chip) but have access to a Windows 10 PC and plan to use this viewtopic.php?f=16&t=22896
I'm totally committed and know I can brick my drive so:
1. Can you guys/girls point me to the correct firmware to flash it with?
2. Anything I should be aware of before I go?
Re: Flash a BD-RE BU40N drive - first time
#2 Post by Coopervid » Fri Jun 03, 2022 3:39 pm
Flash the 1.04 from BU40N-Main in the firmware pack.
outland
#3 Post by outland » Fri Jun 03, 2022 3:57 pm
This one?
New! The all you need firmware pack: https://drive.google.com/file/d/1HRnbXi ... sp=sharing
and this one:
HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Will this work with DVDFab, I want to be able to make Iso's :)
Lbento
#4 Post by Lbento » Fri Jun 03, 2022 6:30 pm
Flash the 1.04MK with the SDFtool Flasher v1.3.3 and the the 1.00DE to work with DVDFab
outland
#6 Post by outland » Sun Jun 05, 2022 11:42 am
So, I should flash it directly from 1.04 to 1.00DE for it to work on both MakeMKV and DVD Fab?
Using this:
DE_LG_BU40N_1.00.bin
Again, thanks!
#7 Post by Billycar11 » Sun Jun 05, 2022 11:44 am
outland wrote: Sun Jun 05, 2022 11:42 am So, I should flash it directly from 1.04 to 1.00DE for it to work on both MakeMKV and DVD Fab?
Using this:
Again, thanks!
No
outland
#8 Post by outland » Sun Jun 05, 2022 2:15 pm
Again, thanks for the reply.
Also, I understand why people would want to buy a pre-flashed drive. For many reasons not what I want to do. So just asking for best advise before flashing :)
So, why no?
#9 Post by Coopervid » Sun Jun 05, 2022 2:45 pm
Please flash first 1.04 or 1.03 MK. Only afterwards flash it again to downgrade to 1.00
outland
#10 Post by outland » Sun Jun 05, 2022 3:51 pm
So first to this one from mk-firmware-pack-20200720:
HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin
Then if I want DVDFab:
#11 Post by Coopervid » Sun Jun 05, 2022 5:20 pm
Yes
outland
#12 Post by outland » Mon Jun 06, 2022 7:19 am
Got this far and everything looks as it is supposed to but nothing happens when I press "Start"
Any ideas?
#13 Post by Billycar11 » Mon Jun 06, 2022 8:06 am
outland wrote: Mon Jun 06, 2022 7:19 am Got this far and everything looks as it is supposed to but nothing happens when I press "Start"
Any ideas?
try closing makemkv
if still no just use the command line from my guide
outland
#14 Post by outland » Mon Jun 06, 2022 8:50 am
Ok, did not do the trick so this command:
makemkvcon64.exe f --all-yes -d D: rawflash enc -i C:\HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin
Again, thanks!
outland
#15 Post by outland » Mon Jun 06, 2022 8:52 am
...and just run it from Windows PowerShell?
